HELP w/ LS1 Tuning Analysis 2[1].1
Using the tuning spreadsheet made by NBM-WS6 Driver I CAN"T get my data to work!! It is so frustrating
Tuning Spreadsheet
Here is my exported data....this time i just exported everything i know to.
http://www3.baylor.edu/~James_Rhodes/EFILIVE%20LOG.csv
Could someone who has had this work figure out what I'm doing wrong and what i need to export and where to put it.
This is very frustrating to have a tool like this and not be able to use it.
TIA
I'm using EFI Live V5 BTW
Tuning Spreadsheet
TIA
Re: HELP w/ LS1 Tuning Analysis 2[1].1
Well my first guess is that you should rename the column headers to match what autotap would call the same values. Or maybe contact bjktx@houston.rr.com with your csv file and see if he will add the column headers to his macros so they will pick it up right.
I'm at work now, so I don't have time to really dig into it, but I'll take a look at it in detail tonight if no one else has posted a solution.
Wow that looks like some powerfull stuff, I am about to embark on an Edit tuning extravaganza. Where did you get that spreadsheet, and how can I figure out how to use it <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
NBM-WS6 Driver made the spreadsheet. You can download the spreadsheet and the help file from the link i posted.
On the first tab "Raw Data" just paste your data in there with column headers....it tells you which variables it uses. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Anyone have a list of the titles that Autotap uses? Im using efilive and i can figure out most of the titles, but not all.
Anyone have any info?
Thanks!
Thanks!
Location: sojourning....looking for my city whose builder and maker is God.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by glitch77:
<strong> Anyone have a list of the titles that Autotap uses? Im using efilive and i can figure out most of the titles, but not all.
Thanks! </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The newest version is able to read EFIlive headings. The only one I have to change is TP to TPS and it works fine now.
<small>[ March 19, 2003, 10:17 PM: Message edited by: Lady Redhawk ]</small>
Set up the titles in the order you like in a template. Use the order of the titles as a guide. The sequence which you check the titles in EFI's export file is the sequence in which they will be placed in your template.
When I export by EFI LIve file, I check the Title & Units then I select "All". I then copy the csv file and past it to the excel program. It will find the headings it needs. The only thing I have to change it the heading TP% to TPS%
It is so nice not to have to check off each PID in the same order of a excel template now.
Thank-you to the creator of the program!
<small>[ March 19, 2003, 10:50 PM: Message edited by: Lady Redhawk ]</small>
