Slam brakes on a dyno..
Old 02-28-2006, 06:08 PM
kukri's Avatar
Default Slam brakes on a dyno..
Here's what the local argument is about:
If a FWD car is strapped properly (cross straped)(Dynojet), would if come off the dyno if driver was to slam on brakes during the pull?
Thanks.
Old 02-28-2006, 10:12 PM
Hennytime's Avatar
FWD is ghey
Old 02-28-2006, 10:21 PM
P Mack's Avatar
No, the force on the straps is still limited by the traction of the tires. Cars reach the limits of traction on the dyno (usually with power, not braking) all the time without flying off.
Old 02-28-2006, 10:53 PM
atljar's Avatar
The drums weigh about 2000 lbs (i think), So it would be trying to slow down a 2k lb weight. More or less what the car weighs
Old 03-01-2006, 08:52 AM
dynocar's Avatar
No, not if the car is properly strapped down for forward and backward motion. Just like dynoing for HP/TQ, the tires will eventually slip on the rollers if you exceed their adhesion limits with either positive or negative forces.
Old 03-01-2006, 08:58 AM
dynocar's Avatar
Oops, I forgot, on dual roller dyno types, used to have one, where the drive tire is pinched in between two rollers and the car is strapped from the rear only, then the answer is possibly "yes". The enertia of the spinning rollers will try to back the car off of the dyno.
slow's Avatar
most dynojet drums weight more than 2000 pounds...
on a dual roller dyno, on a fwd car with small skinny tires, they have a tendancy to want to turn the wheels and go sideways off the dyno. I always find it funny to need 6 straps for a 100 hp focus, but be fine with 4 on a 700 rwhp cobra.
Ryan
Old 03-01-2006, 02:56 PM
Rescue Ranger's Avatar
try and and let us know
Old 03-01-2006, 03:12 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Kinda reminds me of one of Harlan's videos where he accidentally pulled the e-brake while his 'hawk was on the dyno. Oops.
Old 03-02-2006, 06:59 AM
waSStock's Avatar
Ryan
they actually weigh in at 1600-1800lbs...depending on the year it was manufactured.
The additional straps are strictly for side/side force. The "x" pattern, when using 4 straps, does the same thing. Regardless, keep that steering wheel straight.
Old 03-02-2006, 09:05 AM
dynocar's Avatar
If you don't keep it strait and you are pulling against an X strap, this will subtract from the dyno readings. On rear wheel cars we do not X strap unless we have to, such as most Mustangs due to their exhaust routing, because allowing the car to find its own natural position gives the most accurate dyno readings.
Old 03-02-2006, 10:18 AM
Zick's Avatar
Why the f%ck would you want to slam on the brakes.
Old 03-02-2006, 12:03 PM
dynocar's Avatar
If a dyno operator allows customers to drive, expect anything, could write a book.
Old 03-02-2006, 12:38 PM
waSStock's Avatar
LOL...ain't that the truth!
Old 03-07-2006, 01:56 AM
TransAm6383's Avatar
what happend with that??
Old 03-07-2006, 02:10 AM
347fairless's Avatar
Dyno owner here who learned hard way about this. If you hit the brake, you will not be able to keep the wheel straight. Its the wheel turning that makes things scary. Both times the car front wheel started rubbing at a 45 degree angle to the single dyno drum (224). Makes lots of smoke and noise!
Quick Reply: Slam brakes on a dyno..
