Lid Question
Old 03-02-2006, 04:40 PM
JSmee99T/A's Avatar
Default Lid Question
Were there different options to a ram air lid for you ws6 guys or did it change from year to year? My main question is were can i get the bottom of the lid from a ws6?
Old 03-02-2006, 05:00 PM
WILWAXU's Avatar
WS6 Lower airbox/radiator support is GM PART # 12455209
You'll still need to look at an aftermarket lid.
https://ls1tech.com/forums/showthread.php?t=139142
Old 03-02-2006, 09:58 PM
JSmee99T/A's Avatar
why do i need an aftermarket lid? Is it bigger and will my filter still fit? final question does it help alot/any?
Old 03-02-2006, 10:38 PM
rdeterman's Avatar
an aftermarket upper lid gets rid of the very restricting stock baffleing its worth the money...
Old 03-02-2006, 10:48 PM
WILWAXU's Avatar
Check out the link in my last post. It will answer alot of questions for you.
Old 03-03-2006, 08:49 AM
JSmee99T/A's Avatar
I did and all i saw was a lid is a lid is a lid. So that tells me that they are all the same size. I know what a lid does im not that much of a newbie. I just want to make sure that if i do get a ws6 bottom i can still use my same filter to the dimensions of the box (length and width) are the same as a base configuration.
Old 03-03-2006, 09:25 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
You should be able to use the same filter.
Old 03-03-2006, 10:11 PM
JSmee99T/A's Avatar
cool thanks man thats what i wanted to hear.
