Factory speed shutoff
Old 03-03-2006, 12:49 PM
wamp42's Avatar
Default Factory speed shutoff
At what speed would my 98 Formula A4 shut off? Just curious.
Old 03-03-2006, 12:52 PM
Ice Knight's Avatar
I don't think it has one...
Old 03-03-2006, 01:07 PM
ls1charged's Avatar
i dont think it will just shut off they are governed at like 158mph or something like that. so it wont go any higher.
Old 03-03-2006, 01:25 PM
jmm98LS1's Avatar
It depends what your factory tires speed rating was. If they were z rated tires, I think the speed limiter is 149, the non z rated tires was 120 something or less. I'm just guessing on the numbers, but I know there is two different ones and it was based on the factory tire speed rating.
Old 03-03-2006, 01:34 PM
giant016's Avatar
https://ls1tech.com/forums/showthrea...light=governor
Old 03-07-2006, 03:15 PM
RoyO's Avatar
I know for M6 cars at least, it was a 162mph speed limit with Z-rated tires, 120mph with the base tires. I'm not sure about the A4 cars.
Old 03-08-2006, 12:22 AM
brightgreenZ's Avatar
I've got a 98 A4 Z-28 and it hits 115 and shuts down!!!!!!!!!!
Old 03-08-2006, 10:22 AM
Board Certified Idiot
Z2K_MrJ's Avatar
115/120 MPH "R" Rated Tires
From the Factory
149/158 MPH "Z" Rated Tires
Old 03-08-2006, 10:41 AM
wamp42's Avatar
I know its not 115 cause Ive gone 120. My car came with Z rated tires so I think its around 160 like said That sucks if youre Z28 shuts down at 115. An by the way I know the car wont shut down literally, it just stops accelerating. Im not that much of a nube.
Old 03-08-2006, 10:54 AM
~JOSHUA's Avatar
If it shuts down at 115mph it's because it wasn't ordered witht he "Z" rated tires from the factory. Crappy huh?
You can buy a Predator, Crane, Hypertech programmer that will raise or delete the speed limiter.
If you had the Z tires it shuts down at 162 mph. Scary having your car surge forward at those speeds when the limiter hits.
I removed my limiter long ago. Don't need it though, haven't driven over 120mph in a while.
Old 03-08-2006, 12:48 PM
Tiger2o69's Avatar
I never seen an ls1 car without z rated tires... ie one that I have removed the limited and it was not 160.
Old 03-08-2006, 03:21 PM
408 z28's Avatar
well my 2000 T.A. m6 cut off at 146ish if that helps you
Old 03-08-2006, 04:57 PM
zed332l's Avatar
like i told the police officer......it only goes 65 mph.
Old 03-08-2006, 10:00 PM
wamp42's Avatar
Howd that work out for ya?
