Northwest Members WA, OR, ID, MT, WY, SD, ND
think i found the problem
Old 03-03-2006, 07:14 PM
jewbacca's Avatar
Default think i found the problem
if some of you didn't catch my other post. i have been have some problems with my car, it has been running like it is missfiring, but it doesn't sound like it, no backfiring. so i was poking around one of the other forums, and found a guy with almost the same thing. it turned out he had a rip in his intake elbow. when i checked mine i saw it had a rip in the side and the bottom was buckled up allowing air in after the maf. i already ordered a 1le elbow. so could this be my problem?
Old 03-03-2006, 08:28 PM
Z ANGEL's Avatar
Yep, that'll cause Problems. I bet your car will run a lot better now
Old 03-03-2006, 10:10 PM
WAHUSKER's Avatar
Like Steph said, yep. That would probably end up with the computer dumping fuel trying to compensate for a lean a/f that it didn't understand.
Old 03-04-2006, 02:58 AM
TwoFast4Lv's Avatar
Very common Issue. one of the first things I look for
GOOD JOB!
Quick Reply: think i found the problem
