Coolant Temp Sensor Location
Old 03-04-2006, 08:52 PM
bcrishon's Avatar
Default Coolant Temp Sensor Location
I have my sensor right now in the left head and I think it might not be real accurate!! I am running all Auto Meter Guages, but when I compare it with the Tech 2, it is off by over 20 degrees. Is it an option to drill out and tap the top flat spot in the water pump and put the sensor there?? Or what are my other choices?? Thanks for all the help!!
Old 03-04-2006, 08:56 PM
BIRDONNOS's Avatar
what year is your car, if its later than a 98 then your guage will be off as these gauges usually are off and won't read exact.
Old 03-04-2006, 09:01 PM
bcrishon's Avatar
Sorry, I am running a 1999 LS1. What are my options to get that thing to read correctly?? Thanks
Old 03-04-2006, 10:03 PM
LS69TA's Avatar
I don't think you can get it to read correctly. You can put an aftermarket gauge in the car and put the sending unit in the passenger side head, or in a plug above the starter.
edit: do you already have the Autometer sending unit in the pass. side head?
Old 03-05-2006, 08:11 PM
bcrishon's Avatar
I am already running an Autometer guage that is placed in the left cylinder head. I just want it to read somewhat correctly. What are my options?
Old 03-05-2006, 08:24 PM
LS69TA's Avatar
It's going to be accurate for where it is located. I'm not familiar with Tech 2. But if it's taking the reading from the drivers side head, I would assume the temps. would be very close, however I'm not sure the exact routing that the coolant goes through the motor. There will be a variance depending on where the coolant enters the engine and where it exits. So whatever sending unit is closer to the coolant coming into the engine will show cooler than the one right before the coolant exits to go to the radiator. Thay may be where the difference is coming from. Just a guess.
Old 04-26-2006, 11:29 AM
Hersker Hans's Avatar
can i use the stock tempsensor in front of the driver side head on my autometer instrument? i've got a 98 LS1
Old 04-26-2006, 05:59 PM
LS69TA's Avatar
Your '98 coolant gauge reads correct. The 99+ don't. I wouldn't bother with it on a '98 car.
Old 04-27-2006, 04:07 PM
are you kidding? I can use the stock one? now that ive been drilling an tapping and everything , just tapped into the bolt though, so its reversable.
Old 04-27-2006, 06:42 PM
LS69TA's Avatar
Yea the stocker is pretty accurate.
Old 04-28-2006, 10:12 AM
383ss's Avatar
yes, on a 98 you should be able to tap into the wiring of the sensor there. you can not do it on 99+.
98's use a 3 wire setup. 99+'s use a 2 wire.
Old 04-28-2006, 10:59 AM
great thanks for the info
