GT60 and GT67 STS turbos
Old 03-07-2006, 08:33 AM
Bankz27's Avatar
Default GT60 and GT67 STS turbos
I was wondering what were the a/r on these two turbos (normal 60-1 / GT67 ) and how much hp each can produce. (Turbo Spec HP)
I am not 100 percent that is the turbo for the regular STS setup.
For example I know the t-70 supports 700 hp but that is what I read about...but I am still looking
Old 03-07-2006, 06:53 PM
GR33N GoblinM6's Avatar
the standard kit comes with the 60-1, the upgrade is the GT67.. i beleive the A/R are .81
Old 12-11-2006, 12:52 AM
ssdriver27's Avatar
mine came with the gt60-1 with a .96 ar and does pretty good hits 7psi at 2800rpm
Old 12-11-2006, 09:59 AM
98turbls1's Avatar
My buddy's did too...It's weird because they're supposed to come with a 60-1 with a .81 ar but his had a .96 A/R also... Did they change all of a sudden??
Old 12-11-2006, 11:58 AM
JD_Z28's Avatar
I talked to STS and they said it depends on where you live which AR you get. The .81 is on the GT67's and the .96 and .81 are on the 60-1 (depending on elevation).
Old 12-11-2006, 12:14 PM
98turbls1's Avatar
I wonder why...You think that it's probably due to thinner air is harder to spool the turbo?? That's my guess... What do you think John???
Old 12-11-2006, 12:36 PM
JD_Z28's Avatar
I don't know....Once I get the new turbo in with the .81AR I should spool about the same considering my housing I have now.
Old 12-11-2006, 03:29 PM
99Z28LS1's Avatar
i have the GT67 with a .96 and wrapped exhaust and it spools very fast IMO
Old 12-11-2006, 04:00 PM
98turbls1's Avatar
So you are going to put the new turbo on??? Once you get everything doctor'd up you should spool quite a bit faster...It's probably going to pull like crazy once you actually hit boost regardless...
Old 12-11-2006, 09:31 PM
Jake@EPP's Avatar
http://www.exoticperformanceplus.com...Car.php?car=32
Here is a link to a car we did a 383 stroker on, the sts kit had the 67mm variant. Spool is great with the converter. At 7psi this car is a rocket, i have not felt 13.5psi which is 708 on our mustang dyno. The midrange torque compared to a procharger is amazing on this setup. A 72mm or a 76mm turbo would make for great top end power on this combo.
Old 12-11-2006, 09:46 PM
2002ws-6's Avatar
I started with the 60-1 and It spooled real quick but seemed not to take the car to redline. And it sounded like a small turbo real high pitched wine. I changed out to the T-70 and it takes a little longer to boost, even with the same size A/R. But man it pulls so hard. It also sounds like a damn jet engine
Old 12-12-2006, 09:29 PM
NYSS Guy's Avatar
The base 60-1 taps out around 475 rwhp, that was at 8 psi, with a .81 a/r. I skipped straight to the T76, so I don't know the answer to the question on the 67. My 76 is a .96 a/r, and it has hit 10 psi by around 3500 rpm.
Old 12-12-2006, 09:37 PM
...with cheese.
Armageddon's Avatar
I had the 70trim. Best I could squeeze out of it was 624/678. This was on a .96ar also. It was def out of breath at that power level.
Old 12-13-2006, 03:37 PM
Devil's Due's Avatar
I started with a 67 W/.96 then switched to .81.
The .96 reached full spool at 3500, the .81 is full by 2800/3000.
This is in Missouri around 600ft. above sea level.
Quick Reply: GT60 and GT67 STS turbos
