9" center section sale at DLS
Old 03-07-2006, 07:17 PM
LS1Tech Sponsor
Scott@DrivelineSolutions's Avatar
Default 9" center section sale at DLS
We are having a sale for the next few months for our "in house" built 9" center sections. Choose any ratio from 3.00 to 6.50 with your choice of differential or spool. Choose either a Daytona or Billet aluminum support and either a Forged or Billet pinion yoke.
Here are some common center sections that we have build in the past,
Strange S casting with Strange gear, Truetrac differential, Daytona support with a forged pinion yoke, all timken bearings assembled "in house" for $1225.00 shipped with in the 48 states! See pic for example.
http://i35.photobucket.com/albums/d1...centers004.jpg
Strange Nodular casting and gear set, 31-33-35 spline Spool, Billet aluminum support with billet pinion 1350 yoke, timken bearings assemble "in house" for $1115.00. Add $250.00 for Truetrac or Auburn, add $325.00 for Detroit locker in 31 spline. shipped with in the 48 states! See pic for example.
http://i35.photobucket.com/albums/d1...centers005.jpg
Ultra lite ultimate 9 inch package with a Moser through bolt casting, Strange spool 35 spl., billet pro aluminum support, any ratio from 3.50 - 6.00 on street (8620) gear, Billet 1350 pinion yoke, Mark Williams ring gear bolts, Timken bearings and assembled "in house" for $1305.00 shipped with in the 48 states! Rated well past 1000hp! See pic for example.http://i35.photobucket.com/albums/d1...ete_Center.jpg
We do also offer a budget 9" using a Ford motor sport case, up to 31 spline axles, with Motive gears, Truetrac, 1330 Ford Motor Sport pinion yoke, Timken bearings assembled "in house" for $975.00 shipped with in the 48 states. This will also include a conversion u-joint and a set of u-bolts to fit your stock driveshaft!
Visit our site soon, as we are updating to better suit you, our customers.
Thanks for looking, Scott @ DLS
Visa, Mastercard, Discover and Paypal accepted.
Old 03-08-2006, 05:58 AM
Silver Slayer's Avatar
Just out of curiousity, how much power/torque can the TrueTrac handle?
Old 03-08-2006, 07:52 AM
LS1Tech Sponsor
700 or so, they use then in NASCAR road courses and they run over 700hp.
Old 03-08-2006, 09:52 AM
gator's 99TA's Avatar
SO once we get the center section, then we have to have the rest of the rear measured, welded, and hung?
Old 03-08-2006, 12:15 PM
But would they be able to handle a violent launch from a car making that kind of power?
Old 03-08-2006, 03:18 PM
LS1Tech Sponsor
I use and recomend the Moser housing and axle package to complete the assembly. With out ABS I can get you a package for $985.00 shipped with out ABS. Your stock brakes can be reused and your stock backing plate becomes the axle retainer. The SPOHN swaybar mounts are a bolt on item that will need to be order right from them.
Old 03-08-2006, 03:23 PM
LS1Tech Sponsor
Currently I have a few local customers that have gone 1.40's 60' times with out any issues. The unit is just like the Torsen, when it starts to break it will let you know when you turn. The worm gears start to bind against each other and make a clicking noise. I have had only one come back for warranty and that was with a BBC with NOS in a heavy 1970 Chevelle.
Old 03-08-2006, 03:48 PM
OK thanks... There has been several debates about this and I never heard anyone say how much it could handle in a drag race appliacation.
Old 03-08-2006, 06:46 PM
markp03's Avatar
about how mutch does a mouser hoseing and axle package cost?
Old 03-08-2006, 07:00 PM
LS1Tech Sponsor
$985.00 without ABS shipped, with in the 48 states, to your door.
Old 03-11-2006, 10:51 AM
co.6z28's Avatar
just bought a center section, thanks scott
-chris
Old 03-11-2006, 08:48 PM
LS1Tech Sponsor
-chris
Chris, it was nice talking with you and let me know when you need that housing package.
Scott@DLS
Old 03-16-2006, 10:20 PM
LS1Tech Sponsor
Thank you LS1tech members for looking. we have added another center section to the list. Check it out!
Old 03-24-2006, 10:41 AM
LS1Tech Sponsor
I have been unable to get a hold of one customer "Hyde Edwards". I have left 3 messages on an answering machine and I have not recieved a call back form this person. If the customer reads please PM or call me A.S.A.P.!
Old 03-25-2006, 01:10 AM
LS1Tech Sponsor
Sale is back on, Truetrac's are in stock and ready for assembly!
Old 03-26-2006, 12:19 AM
Restricted User
CAT3's Avatar
Scott, what is the pro/con's b/w the Daytona and Billet Alum pinion supports, other than weight? Is the Daytona heavier duty, or equal ( I know its ugly ). I'm looking at getting another center section, an ultra-feather weight spool setup, something for the track only, then I can swap in the N case for DD.
Old 03-26-2006, 01:50 AM
LS1Tech Sponsor
I like to use the Ford Motorsport Daytona support for street driven cars since they have a larger pocket for oiling the pinion bearings. The aluminums are for more weight savings for racecars. I haven't seen any diffferent in strength between the two.
Did you see the pics of PSJ's center section? That thing is so lite I am contemplating putting one together for our project car.
Old 04-17-2006, 11:47 AM
LS1Tech Sponsor
TTT, extended sale until further notice.
Old 08-02-2006, 01:00 AM
99blancoSS's Avatar
Hey this sale still going on?
Old 08-02-2006, 01:51 PM
NOBR8KSS's Avatar
Scott, what kind of power would the budget 9" handle? I would be using it mostly on the street with a few trips to the dragstrip on drag radials. I would be making about 400 rwtq in a M6 car.
Quick Reply: 9" center section sale at DLS
