Does P1SC head unit swap for D1SC?
Old 03-09-2006, 02:43 AM
ChaseSS's Avatar
Default Does P1SC head unit swap for D1SC?
I was just curious about this, if i get a P1SC setup and decide that I want more boost in the future, can you swap the D1SC head unit for the P1SC head unit with no other modifications?
Old 03-09-2006, 04:48 AM
EPP
EPP's Avatar
Yes, they both use the same housing. You can send in an ATI ProCharger P-1SC to ATI ProCharger, and they will rebuild it into a D-1SC for $1,200.00. The price to upgrade from a P-1SC to a D-1SC when you are first buying the ProCharger is normally less than $200.00. Bob
Old 03-09-2006, 04:55 AM
98turbls1's Avatar
It sounds like to me that I would just run the D-1SC from the get go and just keep the boost down a little...that's about a $1000 difference and plus the hassle of switching them out and then the down tme too...Goodluck with whatever choice you make....
Old 03-09-2006, 08:31 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Aslo when you switch from the P1 to D1 your warranty changes to 90 days after the conversion to D1. Even if you have 2 years of warranty on the P1 (like I do).
Old 03-09-2006, 02:03 PM
ChaseSS's Avatar
ahh, thanks guys I guess i will just do the D1 right from the start to save some $$$ down the road....who knew that going D1 would end up saving me money
Old 03-09-2006, 03:30 PM
And the D1 will give 15 psi easily.
Old 03-09-2006, 03:55 PM
Ed Blown Vert's Avatar
Go with the D1. I have the P1 and will have to upgrade for more $$$
Old 03-09-2006, 08:10 PM
Jeremiah's Avatar
I went the P1 also.....
Quick Reply: Does P1SC head unit swap for D1SC?
