GM MLS headgasket p/n (sorry, search is borked)
Old 03-09-2006, 10:12 AM
Bad30th's Avatar
Default GM MLS headgasket p/n (sorry, search is borked)
I found conflicting part numbers for GM MLS headgaskets, need to know which one please so I install the correct ones...
12589226
or
12498544
...or are they the same ?
Need them for my stock bore size Procharged 99 LS1.
Thanks !
Rob (Bad30th)
Old 03-09-2006, 10:49 AM
chronic masturbator
dynedta's Avatar
i used the 12498544
Old 03-09-2006, 07:49 PM
SSmokin 01's Avatar
12589226
or
12498544
Thanks !
Rob (Bad30th)
I got mine (your first #) from TR.
20-12589226 GM Multi-Layer Steel LS1/LS6 Cylinder Head Gasket
http://thunderracing.com/catalog/?ac...vid=3&pcid=157
Old 03-09-2006, 09:46 PM
chronic masturbator
dynedta's Avatar
i wonder what the difference is in know the 12498544 is like 30bux and you get both gaskets
Old 03-02-2009, 07:09 PM
armyspeedfreek's Avatar
any one know im interested
Old 03-03-2009, 04:13 AM
SD99TA214's Avatar
12589226
or
12498544
Thanks !
Rob (Bad30th)
bore size doesnt matter......which heads? 12610046 if your running 317s on your motor imo. you dont wana run 5.7 head gaskets on a 6.0 head. the seal ring will be INSIDE the chamber not outside.......if you got 5.7 heads go with SSmokin 01.
Old 06-07-2009, 04:24 PM
blazin's Avatar
Im putting a set of LS1 Heads 853s onto my 5.3 what gasket do I need?
Old 06-08-2009, 08:17 AM
Rick_Vor's Avatar
Without looking up the part numbers, I'm pretty sure the first pair are graphite and the other part numbers for a single head gasket are MLS (multi-layer-steel). GM switched to the MLS style quite a few years ago.
Rick
Quick Reply: GM MLS headgasket p/n (sorry, search is borked)
