need your quick opinions... ls6 intake of asp pullies for my 98ls1
Old 03-12-2006, 02:27 AM
1fastz's Avatar
Default need your quick opinions... ls6 intake of asp pullies for my 98ls1
i just got some extra cash left over from my taxes and im wondering which upgrade to go with, im thinking either an ls6 intake since i have a 98 or maybe a set of asp pullies, both i think give an extra 10 or so, which one would be best??? need your opinions !!!!!!!!!! thanks guys
Old 03-12-2006, 02:31 AM
blue01ta's Avatar
I say the intake. I don't think you'll notice too much out of the pullies until after a cam swap.
Old 03-12-2006, 02:47 AM
Blacker's Avatar
Both are great mods. I gained 10 rwhp with the pullies and 0.15 secs at the track. The pullies will be cheaper so, it is up to you. With the LS6 Intake, you will need the intake, coolant tubes and tuning. The tuning is for the EGR that you won't be using anymore. Also, with the increased airflow the fueling and spark could be further optimized. The pullies work great on a stock car.
Old 03-12-2006, 03:21 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Snag an intake for sure.
Old 03-12-2006, 06:14 AM
Mac 2002 SS's Avatar
Intake .
Old 03-12-2006, 06:29 AM
227Hawk's Avatar
I'm another one for getting an intake.
Hawk
Old 03-12-2006, 06:31 AM
Moderator
davered00ss's Avatar
Intake. You can get a used one on the boards for $300 shiped. I just sold mine for that locally. You need a front coolant line & rear block off plugs ($30) You will also need block off plates for the EGR on the exhaust manifold ($40 w/ air block offs too, ebay) You can do the intake yourself in a day. an hour if you are good.
The crank pully is a bitch to remove.
Old 03-13-2006, 08:37 AM
DVSWS6's Avatar
Intake. I put one on mine after I had the cam in for about 2weeks and it made a difference over the stock LS1. If you start modding, you'll need the airflow...
Old 03-13-2006, 08:47 AM
peterock98's Avatar
Get the intake and port your throttle body.
