Bolt ons and engine life
Old 03-12-2006, 01:50 PM
Optimus_Prime's Avatar
Default Bolt ons and engine life
I was wondering what bolt ons would most likely decrease the overall life of the engine. Cams in particular...How hard would a T-Rex be on your engine and how much shorter would the overall life be because of it?
I was just wondering because I've started modding my car and i have to keep it for at least 6 years and i want to make sure it stays dependable.
Old 03-12-2006, 01:53 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Depends on how high you rev it and beat on it.
Old 03-12-2006, 01:59 PM
maybe 3 or 4 races a weekend (i dont have much competition here )
I only rev to about 2k driving around town.
I guess my real question is that if I got a full exhaust, heads, and a T-Rex how tough would that be on my engine and how long should I expect it to still be dependable?
Old 03-12-2006, 02:06 PM
Lithium's Avatar
Should be fine just so its maintained properly you know? good tune, light foot every now and then, etc...
Old 03-12-2006, 02:08 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
less than stock for sure.
Old 03-12-2006, 02:40 PM
Tally TransAm's Avatar
ive got 94k on my motor and most of them were put on in 1/4 mile incriments. runs better now than it ever did
Old 03-12-2006, 04:21 PM
Well it seems that with a better intake and exhaust shouldent that make the engine last longer since it can breathe better?
Old 03-12-2006, 04:27 PM
99z20ate's Avatar
its not the engine i would worry about as much, as the stress your putting on other parts.
Old 03-12-2006, 04:28 PM
What are some of the big parts and how much would it cost to replace/ upgrade them?
Old 03-12-2006, 04:30 PM
Lithium's Avatar
Not really cause a restictive exhaust and intake will just bring the hp down a lot. You are taking a risk basically with anything you add to your car, if its done right and is tuned good there is less likley of running into problems. There is no bullet proof way of adding a cam that big along with heads. Its going to shorten the life of the engine - how much I dont know but with the proper care and maintance the engine should last a long time.
Old 03-12-2006, 04:59 PM
Thanks for the help...sorry im such a noob
Old 03-12-2006, 05:05 PM
Lithium's Avatar
Nah dont be...I am too in a way.
Trex is a nasty *** cam man...good luck
Old 03-12-2006, 05:07 PM
jinxedz's Avatar
Like the good nasty or the bad nasty?
Old 03-12-2006, 05:11 PM
Lithium's Avatar
The very very good sounding nasty.
Old 03-12-2006, 05:12 PM
sidewayz28's Avatar
if your worried about engine life why not put a more practicle cam in it? trex is pretty big
Old 03-12-2006, 05:14 PM
sidewayz28's Avatar
(from TR.com)
"Thunder Racing Custom Camshaft - T-ReX v.2 - 242/248 - .608/.612 - 110 lsa 3500-6700 RPM Power Band. Violent mid-range & high RPM power. Requires computer tuning, 4000+ converter on autos, 4.10's or greater on manual trans cars"
Old 03-12-2006, 05:49 PM
Lithium's Avatar
https://ls1tech.com/forums/generation-iii-internal-engine/467728-true.html
Old 03-12-2006, 05:53 PM
TARZAN's Avatar
I don't consider a cam a "bolt-on"....maybe more of a "bolt-IN" lol..
But yeah, there are plenty cars out there with 150K+ on em, with cams...It all depends on how hard you beat on it, how far you rev it, and how well you take care of it (maintenance)...Also, a larger cam will be harder on the springs, so that may be something you wanna consider....But theres always a fix
-Will
Old 03-12-2006, 06:24 PM
blackbirdls1's Avatar
I've heard a trex, I was with one of my buddies at the truck and his friend's friend showed up and had a trex on his ls1, it caught everyones attention.
Old 03-12-2006, 07:26 PM
WILWAXU's Avatar
My stock internals motor went 40K+ miles without a single issue being turned to 6600rpms. IMO, it would have went 100+ if I wouldn't have switched to heads and cam.
