T56 to Th400 short tail. Lengthen Drive Shaft?
Old 03-13-2006, 07:14 AM
Silver Slayer's Avatar
Default T56 to Th400 short tail. Lengthen Drive Shaft?
Has anyone had to lengthen their drive shaft when converting (from a T56) to the Th400 short tailshaft?
From what I can gather it looks like the short tail shaft TH400 will move the mounting point towards the rear by about 1/2". It is also looks about 3 1/2" shorter than the T56.
I like the idea of the mounting point being closer to the T56 and being able to use the T56 crossmember, but I am worried about it being shorter overall and having to lengthen the drive shaft. I can have it shortened for free, but I will have to pay to have it lengthened.
The long tailshaft (9" tail) will move the mounting point about 1 1/2" past the T56 cross member mount, but is about 1 1/8" longer overall.
I do not mind sending the driveshaft back to be shortened, because I do have to send it back to have the Th400 yoke installed anyway. I just do not want to have the driveshaft lengthened and have to pay extra for it.
This is also on a Moser 9" rear, so would I have to make the driveshaft longer with the short tail shaft 400?
Thanks,
Kevin
Old 03-13-2006, 12:01 PM
To the top
Old 03-13-2006, 12:35 PM
Fast SS on TNT's Avatar
Get a better driveshaft. Madman Racing sold me a complete setup for my TH400, including a billet input shaft. I know you think you can save a few bucks by using your old shaft, believe me, if your gonna run some serious horsepower, lose the stock drive shaft.
Old 03-13-2006, 06:11 PM
I am running a Denny's nitrous ready driveshaft now. I can send it back and all the labor is free, I just have to pay for the parts to have it modified. If it needs to be longer, than I have to pay extra.
Does anyone know if it will have to be longer to be used with the short tail TH400
Thanks,
Kevin
Old 03-14-2006, 05:57 AM
Anyone know anything on this?
Old 03-14-2006, 06:08 AM
LS1Tech Sponsor
MADMAN's Avatar
It will need to be longer with the 400.
__________________
www.madmanandcoracing.com
225-343-9029
Old 03-14-2006, 06:12 AM
It will have to be longer with both the short and the long tail 400?
Old 03-14-2006, 06:14 AM
If I get the long tail 400, are there any crossmembers that will bolt right up? Will my Lakewood drive shaft loop still work?
Old 03-14-2006, 06:29 AM
LS1Tech Sponsor
MADMAN's Avatar
You need the short tail it is stronger and if you are going to spend the money on the trans and carry the weight get the stronger version.
__________________
225-343-9029
Old 03-14-2006, 07:16 AM
Do you know of what crossmembers will work with the short tail? I would like to find one with the torque arm mount.
I appreciate the help.
Thanks,
Kevin
Old 03-14-2006, 07:43 AM
cablebandit's Avatar
BMR...it is designed for the short tail and has tq arm mount
Old 03-14-2006, 09:47 AM
john kilgore's Avatar
Default drive shaft
you guys that are asking how long a d shaft will be have to know that there is not just one th400 yoke. so get the yoke you are going to use then get your d shaft made.
Old 03-14-2006, 09:56 AM
I know there are three different tailshaft lengths.. I have a good driveshaft already, I am just trying to make my swap a little easier with less modifications.
I have the option of the short and long tailshafts for my 400, and I was trying to figure out if I would have to pay to lengthen my driveshaft or if I could get it done for free by shortening it.
It seems like if people spent more time reading the intial posts then they would have would understand more of what is going on.
Old 03-14-2006, 01:08 PM
Default yoke
l think you missed what l was trying to say. the yoke is the thing that goes from the output shaft to the front u-joint
Old 03-14-2006, 02:58 PM
black01_WS6's Avatar
spohn makes one just for your application. i would look them up.
Old 03-15-2006, 06:03 AM
I was thinking that you were putting me in the "what length driveshaft do I need " category, sorry.
This is the first that I have heard of the yokes being a different length, what lengths do the normally offer? Are they typically longer than the T56 yoke, or shorter?
Old 03-16-2006, 06:09 PM
Default yokes
they come in many differant lengths. non will let you use your d shaft with out modification
Old 03-17-2006, 06:04 AM
Well, I knew I would need a new yoke, but I was not sure about the length of the ds. I have the Denny's drive shaft, so the labor would have been free to modify it, except to lengthen it.
Thanks for the help,
Kevin
Quick Reply: T56 to Th400 short tail. Lengthen Drive Shaft?
