MCleod Master Drill Mod
Should this be done or not? Or will doing so affect it in anyway? I'm putting in the Mcloead adj master spec 3 and steel flywheel and an 02 slave cyl. Thanks
Rick
Rick
Don't drill the actual master cylinder. That orifice is plenty big. Only drill the stainless hose that you remove from the stock master. Drill out the hole that goes into the master cylinder. There are plenty of write ups out there. And the McLeod master cylinder should come with instructions that explain the "drill mod" also.
Andy
Andy
need to do the drill mod if your producing 400 rwhp, because pressure release will get restricted and u will burn up the clutch (especially the spec). happened to me 2 times before i fiqured it out thanks to eastside....
