Any Gains With The Csr Water Pump
higher flow rate, added hp (reduced parastic loss), ability to run the pump with the engine off, and the flow isn't rpm dependant...................i really don't see a reason NOT to get one.
Originally Posted by jessebuickguy
A lot of good reasons to get one, but are they reliable for daily driving?
they're rated around the same number of hours as the stock pumps, so yes.
Originally Posted by ss97dml
i was told by amy engine builder NOT to use one!!! saysthey always flow the same rate and could cause hot spots
they flow the same as a stock pump...at say 5,000 RPMs
I have had mine on the car for over four years now no problems racing or daily Driving
i think he meant they don't change the rate of flow like the stock pump will, seeing as they're electric. I see what he's saying but you'd think someone would have noticed after all these years if they did in fact cause hot spots.
what he means is when your twisting 7500 RPMS, the flow rate will be the same as idle. He is partially right. When you give the car RPM the alt will create a slight amount of charge increase which will spin the pump slightly faster.
That aside, unless your turning 7500 RPM on an insane motor, your going to be fine with an electric and it will cool great.
I see what you're saying. I don't know how much more voltage the alternator actually would make, assuming the voltage regulator is working correctly, but it definitely does make sense.
