Clutch help pleazzzzz??
Old 03-17-2006, 01:31 PM
blackbird00's Avatar
Default Clutch help pleazzzzz??
Ive been working now the 2nd day on thsi my clutch wont bleed and i guess there is air stuck in the line. Last night i took off teh master cylinder and cleared all teh air out of it. It worked at first but as soon as i drove on my way home the pedal would sink in a lil and only get pressure at the very bottom likde right before the floor. As soon as i get off work at 430 im going to mess with it again. And it seems liek i have to pump it while im driving other wise i cant get it to shift into gear. Any suggestions or anything???
Old 03-17-2006, 01:52 PM
renips's Avatar
When you were putting in the fluid did you have someone pushing in the clutch pedal until it was filled?
Old 03-17-2006, 03:37 PM
bigdsz's Avatar
With out a doubt, the problem is bleeding your slave. A guy on this site steve-d has a slave bleeder extension that he sells that works great. Recently I installed a Spec 5 and McLeod bellhousing that would not allow me to bleed the slave so I got this extension and that solved my dilemma.
Old 03-17-2006, 03:52 PM
ya someone today said they also think its my slave so im starting it right now im going to try and bleed it and hopefully that works.
