Problem with spec install! HELP!
Old 03-18-2006, 06:21 PM
camarodave98's Avatar
Default Problems after spec install! HELP!
I just got a call from my mechanic who is installing my new spec 2+ and billet flywheel, and he says its having some issues. It wont go into reverse unless the car is off and you just force it in?? Said driving in forward gears is "ok" but sometimes difficult to go in. What could be the problem? He is suggesting just drive it around and "break it in" but im thinking something might have been installed wrong? I have a 98, all hydraulics are stock, he says they arent leaking and work fine.....HELP!!
Old 03-18-2006, 06:42 PM
Krab's Avatar
Did he install the shim that goes between the slave cylinder and the tranny? Spec clutches are supposed to come with this shim.
Old 03-18-2006, 06:53 PM
he said he did, and that was one of the first things he thought as well...
Old 03-19-2006, 10:31 AM
To the TOP!! ANYONE>???
Old 03-19-2006, 11:04 AM
jerflash's Avatar
well...either he did not bleed it right or he did not shim it....or if he really did not know what he was doing and used and impact or the wrong touque pattern on the pressure plate...he may have warped it
that would be bad but if all else was taken care off...thats all i see happening
a buddy of mine did another buddys clutch and used and impact to save time and it would not go into any gear when on
Old 03-19-2006, 11:27 AM
well he said it goes in all the forward gears, just not reverse?
Old 03-19-2006, 11:41 AM
jerflash's Avatar
yes i know that but he said that going forward was just ok and its still tough...meaning he is forcing it and rev. would be the one that would not go in on these cars because in my experience its the hardest to go in period
Old 03-19-2006, 12:17 PM
UPDATE: i just got back from driving my car, the forward gears work fine, seem to be normal, but still will not go into reverse while my car is running.
Old 03-19-2006, 12:44 PM
AINT SKEERED's Avatar
Check and make sure the reverse lock out is plugged in.
Old 03-19-2006, 04:08 PM
is it normal for it to be difficult to get into gears sometimes during the break-in period? They always go in, but going from nuetral to 1st can sometimes be stubborn...?
Old 03-19-2006, 04:22 PM
EPP
EPP's Avatar
Question
No, it should go right into gear. Bob
Old 03-19-2006, 09:57 PM
anyone have anymore thoughts? He said he bled it correctly and put the shim in correctly, pressure plate is in place...? Im going to call spec tomorrow, but if anyone knows of anything else, please let me know!
Old 03-19-2006, 11:14 PM
DONAIMIAN's Avatar
I say he got the skip shift and reverse lock out plugs mixed up.
Old 03-20-2006, 05:05 AM
LS1Tech Sponsor
Slowhawk's Avatar
If the clutch is grabbing right off the floor that is the cause of it not going in reverse and is stubborn to get in 1st.The clutch is not disengaging enough.There could be many reasons for this from a wrongly installed clutch (PP not pulled in evenly) to a crappy old slave cylinder (we always change them if they are not 01+).
If it doesn't go into reverse ever when running then it could be the reverse lockout.
Old 03-20-2006, 06:52 AM
Blown408's Avatar
I agree, been there and done that.
Old 03-21-2006, 10:35 AM
where is the reverse lockout plug? Is it something I need to take it back to do? Or something simple as it sounds of just plugging it in?
Old 03-21-2006, 10:46 AM
DONAIMIAN's Avatar
theyre both on the drivers side of the tranny, should be able to do it with only a jack and jack stands. even ramps.
Old 03-21-2006, 01:58 PM
Studytime's Avatar
Sounds like it could still be a bleeding issue. Have you attempted high RPM shifts yet?
Ben T.
Old 03-21-2006, 02:05 PM
DONAIMIAN's Avatar
I didnt really answer your question
The RLO is on the drivers side directly under the shifter.
Old 03-21-2006, 03:41 PM
tici's Avatar
My Spec did the same and I had to make the master adjustable (the clutch wasn't disengaging enough).
A guy at Spec told me that sometimes the shim they supply isn't enough and it's necessary do add a thinner shim.
I didn't wanted to open up everything so I did the master job.
No more shifting problems after that
Quick Reply: Problem with spec install! HELP!
