Victor JR intakes IN STOCK
Old 03-20-2006, 12:13 PM
Restricted User
NBM2001z28's Avatar
Default Victor JR intakes IN STOCK
I have two brand new Victor Junior intakes for $399.99 Plus shipping in stock. Most places sell these but do not have them sitting in stock. If anyone needs one PM me. The kit includes hardware, the intake, and the fuel rails.
Thanks
Mike
Old 03-20-2006, 12:59 PM
777's Avatar
What kind of fuel rails. Are they similar to speedinc's or nasty's?
Old 03-21-2006, 07:24 AM
Fireball's Avatar
here are what they look like:
http://home.comcast.net/~tfranklin5580/victor1.jpg
http://home.comcast.net/~tfranklin5580/victor2.jpg
Old 03-21-2006, 09:12 AM
777's Avatar
What is all needed to make this work. I don't see a place for the map sensor and stuff.
Old 03-21-2006, 10:55 AM
Fireball's Avatar
Just about everything...definately not a direct bolt-on swap.
Old 03-21-2006, 03:45 PM
Restricted User
NBM2001z28's Avatar
Fireball is right, you need a throttle body that excepts the stock tps sensor and iac sensor, accufab makes it, and then you'll need some fuel line adaptors/fittings (same as you would with the fast rails) as far as if they're different then the fast rails, they look the same. Both are of high quality and dont see any differences besides color in them. The Victor Jr is made to flow from 3500-7500 and will make more power over a fast set up. I've read all of the info i could on them on here and everyone who is running them seems to be very happy. They have a huge amount of room to be ported as the fast 90 will run out far before the victor jr has. The one that we're working on new is flowing over 30 cfm more then the ported fast 90 and it still not finished yet.
Mike
Old 03-22-2006, 10:56 AM
Fireball's Avatar
to give an idea on fit in an F-body with a wilson elbow:
http://home.comcast.net/~tfranklin5580/engine_side.jpg
http://home.comcast.net/~tfranklin5580/engine_front.jpg
Old 03-22-2006, 12:14 PM
777's Avatar
What about an elbow like PSJ has. Also where does the map sensor, vacuum line for hvac, and brake booster connect to?
http://psj.ls1tech.com/gallery/main....avId=xb3c53178
Old 03-22-2006, 06:14 PM
Fireball's Avatar
there is a NPT port on one of the runners that'll work good for the brake. Side of manifold has a smaller port which I think you can run a vacuum line to the MAP. you don't need any stinkin' HVAC
Not a fan of the shorter elbow, think it disrupts flow some and adds an awful lot of plenum volume
Old 03-22-2006, 11:24 PM
BLWN1's Avatar
Originally Posted by NBM2001Z28
Fireball is right, you need a throttle body that excepts the stock tps sensor and iac sensor, accufab makes it, Mike
How much is the accufab?
Old 03-22-2006, 11:31 PM
oldschoolmuscle's Avatar
where do you get the fuel line adapters?
Old 03-23-2006, 12:53 AM
Aaron's 00 TA's Avatar
I thought this setup only made more power than a FAST 90mm when it was in the upper(6500rpms) and if you went speed density.
Old 03-24-2006, 07:29 AM
Restricted User
NBM2001z28's Avatar
Russel makes the stock fuel line adaptor, Nasty N8 has them in stock.
Old 03-24-2006, 07:31 AM
Restricted User
NBM2001z28's Avatar
Not sure, i havent looked it up, we've been slammed all this week and me and nick have been there for 12 hours a day a couple of times this week trying to get everything finished up so we can have a couple cars back in time.
Mike
Old 03-31-2006, 01:53 AM
regal's Avatar
I am interested but cannot find a price or part # on the elbow, is there any help with this?
Old 04-03-2006, 08:07 AM
a98ws6's Avatar
A sponsor sells them. Intakeelbows.com I think?
Old 04-10-2006, 09:23 PM
ls1408cp's Avatar
do you guys still have any of these in stock
Old 04-12-2006, 04:47 PM
beardWS6's Avatar
I`m thinking of going this way also!
Old 05-06-2006, 04:50 PM
GIGAPUNK's Avatar
Any chance of you guys running one of thes against an LS6 or Fast on a dyno?
Please?
Pretty Please...
Quick Reply: Victor JR intakes IN STOCK
