Opti questions... I've searched but want opinions
Ok, my opti quit right at an intersection and in traffic. I dont ever want to have to push my car out of an intersection again because of a damn opti. What do you guys suggest/what has worked for you. I know the GM one isn't bad but i'm thinking aftermarket.
MSD, ACCEL, Delteq, conventional small block distributor, and theres a few more.
Any feedback of any kind? I've done the search thing and have no real answers.
Thanks in advance fellas,
Doug
Doug
check www.dynaspark.net i bought one from them they were the first to build a custom unit for the lt-1 and i`ve not had any problems is cost $600.00 but i believe it to be well worth it. dynotech use to own it but sold the rights to the product but it is still being made check the webb address above it should lead you to it the delteq is about 700-800.00 dollars last i looked but it has a lot of custom work you will need to do the dynaspark is as simple to install as the original
that was the other one I didn't remember.....
Another forum view of this same topic.
http://forums.corvetteforum.com/show...48&forum_id=48
Doug
Doug
Delteq is ok if you like to just plug n play and don't mind the big ugly 4 coils. A lot of us prefer the LTCC (both Delteq & LTCC are comparable but LTCC gives you advanced timing control, etc, plus it can be made to look much nicer installed. Search around these posts.
