How Much?
How Much?
Well I have a race on Memorial Day with a 88 fox that runs 8.00 all motor in 1/8 and 7.1 on 200 shot 1/8...My car runs 8.00 all motor in the 1/8th also, so what shot would you all recommend me spraying so I can shut him up.
put colder plugs in and see if you can pull a few degree's of timing and I hope you have a fuel pump then spray 200 sometimes shuting someone up is worth the risk besides a forged engine never hurt no one
unless your very rich dont risk blowin your engine up just to win a race lol. an LS1 with a proper n20 install and tune can eat up a 100-125 shot without much worry. Look around and ask lots of people before you try a 200.
Any amount of spray is a gamble, but just do some research before jumping into a 200 shot. A 200 shot is going to take more than just the bottle. At a minimum you will need a larger fuel pump, a dyno tune, and possibly bigger injectors. I guess the question you should ask is would you rather lose the race or lose your motor?
Yeah, to do what you're going to need to do to win, it will take a fuel system upgrade... as in injectors and pump.
You will definately need a good tune after changing the fuel system like that.
When that's done you should be able to handle a 200hp shot of N2O and very likely win your race if you can hook it.
