Possible budget bottle heater (50 bucks max) if this is correct.
Okay, ive never owned a nitrous car, nor a nitrous kit but after looking at bottle heaters they look earlily similar to the heat pads i use for my tarantulas/snakes/geckos. At any pet store, if you look in the reptile section you will find these heat pads for all variety of sizes for tanks from 5 to 50 gallons. Granted i dont know how hot these things get (never enough to actually burn you, but it does get VERY warm) and from the looks of it, a 20 gallon heat pad looks like similar in size to a bottle heater. COmpanie that make this product are "Exo Terra" and can be found at your local pet store. Take a look at pics online if you want to, and tell me if this is a halfway decent way to save money on a bottle heater.
http://www.exo-terra.com/EN/products...nforest_i.html
this is one of the 3 they offer, this ones for rainforest creatures, its basically what seems ideal as it says it doesnt get overly hot like the desert one. that tank there showing, is a little bit smaller then a bottle for size comparision.
Hmm if I were you I would just run an actual pressure adjustable or temperature controlled bottle warmer. I dont know as to whether or not one of these would work but it just seems like spending the extra money would be worthwhile. My .02...
It would be so much trouble having to really keep your eye on the bottle pressure and trying to figure out exactly which one to buy. I would just spend the extra money on a true bottle heater. You can get them to monitor bottle pressure and will automatically shut off. That is the way i would go. Well worth the extra money.
you'll find those flexible "cloth" heating elements in alot of things... another example is a waterbed heater.
the catch is, most are 120v.. made for household use... some plug into the wall, but use a stepdown transformer.. alot of those can be used in our cars.
you'll find alot of generic products are re-badged as automotive, prices raised and resold... thats just the nature of the biz.
another example are AN fittings.. goto a automotive place, they're pricey... goto an aircraft place, they cost even more.. got a hydraulic store for the same fittings.... they're cheap. and sometimes rated for even higher pressure... just watch what the O-rings are made out of if you're running fuel...
I hate to admit it, but I have thought (a few times) about how simple it would be to install a power inverter and a 'cheap' lizard warmer. I can't help but 'think' about it! The heater is very thin and low profile and gets hot fast! Adhesive backed, easy install... (We had to put a towel on the floor of the lizard house before he would lay on it, It was too hot for Izzy before the towel got thrown in there. It was a little too hot to keep your hand on for very long) My bottle IS mounted within arm's reach, so I COULD easily monitor the pressure if I 'borrowed' the heater off of Izzy's floor...
The lizard has lights and stuff, We gave it the 'hook-up' when we built it's house! He wouldn't have to suffer or anything by not having his floor heater for a little while.
But then I start thinking about the HSW heater and I come back to reality...
It is defititely going to cost me a few more $$$ and more time to install the HSW heater, but at least I will not have to listen to my friends 'goof' on me for dropping all that money in to a really nice nitrous set-up and then 'cheap-out' by slapping a $10.00 heater on it. I guess I might as well just do it right the first time and avoid the ridicule I guess.
HSW (I hate the guy that sent me the link to their site...)
Last edited by BigDaddyZ28; 03-25-2006 at 11:11 AM. Reason: Added a picture of Izzy's house we built (wife and me)
