A4 to M6 Swap!
A4 to M6 Swap!
How hard is this swap on a 99 trans am? I am very much considering doing this. Anyone that has done this have a total cost of everything that is needed and what kind of work needs to be done?
https://ls1tech.com/forums/automatic-transmission/200477-m6-a4-a4-m6-conversion-info.html
thats the best i can help ya
I'm planning to do the same thing, I found a kit for 1400 from someone on these forums and will probably do all the work myself with help from a friend. So I won't spend much more. His clutch and flywheel isn't very old either so I will just resurface the flywheel and throw them in. I will just need the lubricants, some wire, harness adapters, and a tune. Hopefully no more than another 400-600
