Spark Plug Wire Choices?
I am curious as to what spark plug wires you are running. I was looking into the Taylor Thundervolt 50s but they are 10.44. Is that too big. I was hoping to run these with Made For You centerbolt looms. Is this possible. Thanks for any info.
I runTaylor Thundervolt 50's and they have been working great for two years. the only thing is that they are a little difficult to route. You wont be able to use any of the stock seperators. I was still able to route them nicely. the most difficult part is where they route behind the pwr steering pump on the accesory bracket. recently I Ohmed them out and they still have around 50 Ohms of resistance. Also they have great heat resistance, I'd definitly buy them again. AQs far as using the center bolt looms, they are pre sized to the factory lenght wires, If You can get a universal set then You will be good to go.
