Nitrous Dyno Thread....
Come on guys post your RWHP , TQ & your nitrous kit .Post it`s dry or wet & if your car M6 or A4 .Lets see the biggest nitrous RWHP & TQ . ttt
Thanks.
Thanks.
heres an old dual stage using two rpm window switches on my 385 iron block from a several years ago. It made a 715 rwhp and 720 tq on a later dyno but I dont have that one. It was dual stage dry
Here is one on a 408 with a dual stage Progressive dry/wet direct port as controlled by the FJO mini controller. Note the rpm when the run was ended. we were tuning at this point and it was too lean. Also note the HP the 408 made with the nitrous tune NA.
Here is the same car after tuning. There is no Tq or rpm because we couldnt get the pickup to read right through a run and it makes the RPM grapgh nearly unusable. So it must be put in MPH.
here is my old 415 ci motor and nitrous dyno. The nitrous was using the NX Maximizer in rpm mode from 0% ramping to 100%. It was a 200 shot direct port. Pretty damn smooth.
LS1 Tech Administrator
Now you see why I've been preaching the progressive controller. Makes your power curve look more like a turbo curve. Much easier on the engine and driveline when you don't shock it with 100% all at once. Nice graphs!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
It's not half as impressive as the big boys. But this was a 350 dollar NX wet kit using standard 150 shot jets on a 2000 Corvette M6 with only a VaraRam. Everything else was exactly how GM built it.
Here's some video to go along with that dyno sheet for JeffT If I remember right, the specs on the cam were in the 224/230 range
Dyno + 1/8th - Dyno
1/4 - 5 dollar milk shake
Dyno + 1/8th - Dyno
Was it a direct port or a TNT ring. I didn`t think you could go bigger than a 200 shot and be safe? Let me know, Thanks!
