Just finished installing my stand alone!
I just got done testing my stand alone at WOT but with out nitrous for now.my wide band went from 12.5 AFR to ~10 AFR holding steady so I know it's working . I'm going to test it with a 100 shot of nitrous tomarrow starting with 62 PSI from the stand alone fuel regulator. Well see how It goes.
Closed ex-Sponsor Account
The more I see these the better I feel about people running those large shots if that is in your plan... Nothing takes the place of octane in a nitrous car, more the merrier.
Ricky
Ricky
Thanks everyone for the complement's
Yes this is dave's setup.
I have the arm switch power feeding a pilot relay, That pilot relay then sends It's own power from the battery through a 30A fuse, through a normally open contact on the pilot relay to the stand alone fuel pump.
Originally Posted by Firechikn
Is that Dave's set up ? Looks good, thinking of one of these myself.
Originally Posted by MeentSS02
That is a NICE setup...how do you have the fuel pump wired to turn on? With the arm switch?
