Strange 12 Bolt Rearend Group Purchase!
We are running a group purchase for the Strange 12 bolt rearends.
PRGOP8 Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Super Strength posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor at the axles - usually for traction control cars) $2469.99 - GP price - $2174.99
PRG210-PRGOP-14 Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Super Strength posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor on the top of the pumpkin) $2469.99 - GP price - $2174.99
R5206 Upgrade to aluminum support cover $114.99
gmbbp Options: You will either need to send in your brake backing plates or you can purchase a set to be built into the rear (1998+). If your car has traction control you will need to send in your backing plates along with your axles so Strange can use the reluctor rings. $229.99
gmbbpcore Options: If you can't have any vehicle downtime we can charge you $229.99 for a set of backing plates and send them to Strange to be build into your rear. After your 12 bolt is installed you'd send your stock backing plates to us and we'd credit you $175.00. This option is only available if your car does not have traction control or the ABS at the axles. The backing plates are only required for 1998+ cars.. $229.99
Gear ratios available are 3.42, 3.73, 3.90 and 4.10. The 3.90s will be noisy so Strange doesn't promote this one. This rearend comes standard with the Super Strength posi. Each one is shipped ready to be installed. You will just need to swap the brakes from your current rear. Shipping is freight collect for this product so you will need to take care of that with the driver when he delivers. The trucking company will call a few days ahead of time to set up the delivery. We don't have any freight charges for these. That is usually between $125. - $250.
This GP will be wrapping up on Monday, April 17th. Orders can be placed online or by calling 1-877-4-TBYRNE (1-877-482-9763). The first batch of rears will be ordered when we receive 5 orders so it will be beneficial to place your order early!
Have a good day!
Have a good day!
Got any prices on spool rears, can you get 4 channel with sppol ? I would want everything install, reluctors, backing plates etc, ready to bolt on and go !
Thanks
Thanks
Strange won't set up a spool with 4 channel. The spools only come as a race setup. No traction control or ABS. You would need to send in your backing plates/caliper mounts.
