Clicking noise
Old 04-06-2006, 09:21 AM
F-bodyLuv's Avatar
Default Clicking noise
When i rev it up it sounds fine but as soon as the RPMS fall back down i get this clicking noise on the passenger side near my header. Anyone know what this could be?
Old 04-06-2006, 11:48 AM
OctaneZ28's Avatar
Sounds like an exhuast leak.
Check the header bolts, retighten where necessary.
Old 04-06-2006, 12:52 PM
Z28LS1camaroguy's Avatar
yeah i have the same problem on mine right now only its on the driverside, and come to find out the Y pipe somehow managed to make its way off the header and thats what the sound was that damn Y pipe is a pain in the ***.
Old 04-06-2006, 05:52 PM
F-bodyLuv's Avatar
It sounds almost like its coming from inside the valve cover tho
Old 04-06-2006, 06:02 PM
well you do know the walls of the long tube headers are thinner and you more air can go through so you will be able to hear more than the thick stock manifolds, but you could always check your header gaskets to see if thats the culprit.
Old 04-06-2006, 06:27 PM
98camaroLS1M6's Avatar
Do you have stock metal gaskets? They never blow out, but paper and ones that come with headers usually do. Stick with stock gaskets and tighten headers to 18ft-lbs.
Old 04-06-2006, 06:28 PM
2001NBMZ28's Avatar
Start the car in complete darkness - make sure it's not just a plug wire arcing on the header, buddy of mine had a "ticking" noise and it was the plug wire on #6, in the dark we found it right away.
Old 04-11-2006, 01:08 PM
F-bodyLuv's Avatar
Sorry to bring this back to the top, but i figured it out...
Rod knock. At 62001 miles....
Time to open her up and re build the bitch with some nice new parts!
Old 04-13-2006, 12:14 PM
black99ta's Avatar
I like that attitude! You've turned a disappointing repair into a kicka$$ opportunity! Tear it apart and post some picks.
