Any good WOT brackets and switches for the vett??
8 second mod
lets see some pics of switches, and wot's on the vetts. need some ideas how im going to do it. i know they go inside on the gas, but anyone make easy and nice brackets?
i will have
arm, bottle opener, heater, and future possably a purge.
i will have
8 second mod
Originally Posted by Nitro Dave's Nitrous Outlet
Brad,
I would use our digital window switch with the built in TPS. As for a bracket that mounts the micro switch at the pedal I do not think anyone offers one. You will have to bend the universal bracket to fit your needs.
Dave
Dave
i tried one, it got screwed up, put another on it, it worked for a while then came unajusted, so i went to the good old $5 micro switch, and i plan on sticking with it. if you know anyone that wants to buy my good tps one let me know.
any nice switch pannals?
Originally Posted by Noyzee
i have 2 of those sitting in my tool box. i hated it.
Dave
8 second mod
Im pretty sure we are talking about two different switches. Our TPS and window switch combo does not use set screws. Also the Zex unit also does not. There are newer TPS units on the market these days that are awesome.
Dave
Dave
you have a link for yours?
Noyzee- I'll agree with you on the older TPS units, I didn't like them much either. However, there are newer ones on the market that are much much better. The newest one from NX for example, you just wire it into the system and all you have to do to set it is push a button and then push the gas pedal to wot twice and it sets itself. The combination window switch/TPS switch is also another new one that works great and is easy to set.
Regardless of which one you might choose, I would highly recommend using one on a vette. The main reason being that the throttle input from the pedal is interpreted by the ECU and then a signal is sent to the throttle body based in various paremeters that are measured by the ECU. That means that what you are doing with the pedal is not necessarily the same thing that the throttle body is doing.
8 second mod
now i need info on the window switch/wot switch!!!!!
Brad,
This is the window switch combo.
http://www.nitrousoutlet.com/catalog...product_id=964
Here are the new style TPS's
http://www.nitrousoutlet.com/catalog...del=85&dept=11
Dave
Dave
thanks for the info.
8 second mod
Brad,
Dave
Dave
you do american express?
8 second mod
We take every card except american express. Sorry.
We can take pay pal also.
Dave
Dave
i will try to get my buddy to pay pall you.
send me a pm with a total!
Here's the standard mount most guys use. The tps is not needed if you shut your traction control off, but leave active handling on. I run the LAPTRAX, it automaticlly puts car into competition mode (traction controll off, Active handling on) everytime you turn key on. You can still overide and turn traction on manually if weather conditions warrant.
Robert
Robert
8 second mod
Robert
Robert
i forget all the time
it really sucks that i read this thread now cause when i ordered from dynotune i was not aware of the need for a tps switch and nobody else told me anything so i went with the msd digital window switch instead and now i'm kind of stuck,i should of gone with the tps/windowswitch and it was only 30$ bucks more.
TPS (Microswitch) is included with the DynoTune kit (at least it was with the dry kit I purchased). Its just one less component to install if you buy the combined unit TPS/Window Switch.
