tranny cooler with FTRA
Old 04-07-2006, 01:29 PM
v8hunter's Avatar
Default tranny cooler with FTRA
What have you guys done for a tranny cooler that also have the fast toys ram air kit installed. I currently have a b&m 24k kit, that will either need to be relocated or replaced with another cooler. My thought is to get a different cooler that is thin enough to slide in (the 1" gap) between my ac condenser and my radiator. My b&m is 1.5" thick which will not fit and I have not come up with a better idea or place to put it where it will get good airflow through it.
Can anyone here help me out?
Thanks in advance
Old 04-07-2006, 02:46 PM
2001NBMZ28's Avatar
I did mine "dope style." My brother had room to the right (pass side) for his, we both have FTRA and the 24K.
Old 04-07-2006, 03:22 PM
GregWS6&z28's Avatar
dope for sure
Old 04-07-2006, 04:52 PM
v8hunter's Avatar
I don't quite understand what you mean by "dope style". Can you explain what you mean or post a picture.
Old 04-07-2006, 05:01 PM
senicalj4579's Avatar
the size of the cooler i use is .75" thick. and thats all you really need. as of right now i am installing the super sucker ram air and this scoop angles away from the radiator so you will not run into that problem. is is abs plastic also so the it wont absorb heat. if you want to stay with a bigger cooler you might want to consider looking at this system. if not you will have to get a smaller cooler.
Old 04-07-2006, 05:20 PM
2001NBMZ28's Avatar
Dope's link isn't working right now - there's a few pics from people who have mounted it that way at www.ls1tech.com/forums/showthread.php?t=476059
Old 04-07-2006, 06:05 PM
theres an idea but its to bad the fan will not be blowing on it. i can see the reason for a larger cooler for that kind of installation. also if you spend most of the time driving on the high way its a good way to do it.
Old 04-07-2006, 06:09 PM
v8hunter's Avatar
Thanks for your help
