Th350 Questions
Th350 Questions
I installed a TH350 trans and Trex cam. The converter is a Vig.4000 stall.
The question I have is about the power i lost over my 4l60e and 3200 tci stall and Hot Cam. My car put out 350rwhp and 380rwtq before and now I have 336rwhp and 471rwtq. Is this normal? It of course feels faster but It's not showing it on the dyno. The torque is but wheres my Horsepower.
LS1TECH Sponsor
M6 > TH350 I lost 35 RWHP. The car was .3 faster at the track. It would have picked up more but I need to get past the mental block that there is no longer a clutch to brake.
You have to remember the TH350 uses a non lockup style converter so you will never get an accurate dyno. The engine RPM is actually higher than what is being produced on the transmission input shaft because of converter slippage. Like it has been said take it the track to see improvement, the dyno cannot tell you all.
Originally Posted by BAIN
something doesn't sound right. Are you sure you installed the cam correctly ie..not a tooth off? What did the cam pull to?
Can you post a graph?
