First Startup!!!!yeahhhhhh!!its Alive!!!
IM giddy as a school girl.We started her up tonight!the vid is short and sweet,its basically headers to crossover pipe and open from there.with the turbo and muffler itll be ALOT quieter.Some things to mention,as soon as i turned the key it fired up that split second, NO hesitation.Good oil pressure,good fuel pressure(actually had WAY too much at one point til we adjusted the FPR).The gauges look sic IMO.Its finally coming together!!!!!!!!!Nick
http://s5.photobucket.com/albums/y15...t=teardown.flv
LS1Tech Sponsor
W0000t, well done. Hopefully soon ill get that giddy school girl feeling after starting up a completed car! Im jealous, lol
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
frcedfed...thanks man,youve been a big help...and i gotta have some bling
69.....yeah i have....a long time coming
h&h.....thats the pham budget with shortys that i got coated and custom cold side piping
Stoleit....we dont descriminate....so long as it makes an *** load of power!
actually its not bad.....were looking at 3" when it sits on the ground...BUT where that is is even with the tires so for example if i go over a speed bump i dont have to worry cause the tires will raise it up....the next lowest point is passanger cold side pipe but its ~5-6" so i should be ok so long as i dont get careless.
Thats what I thought when I put the P@#m kit on, Careless or not you will smack it and you will start to hate it
You should look at some ovalized pipe from http://www.drgas.com/store/home.php?cat=8
Give you some great clearance.
J
J
