450 Bhp
Old 04-17-2006, 01:59 PM
Pete 1's Avatar
Default 450 Bhp
When my conversion is complete, I`d like the engine to be producing around 450 bhp.
What would I have to do, to my LS1, without internal work ?
I`m not having belt driven power steering, as I have an electrical pump, and I`m doing away with air con.
Because space is limited, I`m gonna have to stick with standard headers, the exaust will be custom 2 1/2" to suit the car.
What would you guys reccommend ?
Thanks
Pete
Old 04-17-2006, 02:17 PM
conan's Avatar
What is it going in?? Does it have a ls6 intake (no egr)?? If you have the ls1 intake you can get a ls6 intake. A ported TB, underdrive pully. Are you looking for crank HP or 450 at the wheels??
Old 04-17-2006, 02:31 PM
Pete 1's Avatar
Have a look here bud ..... https://ls1tech.com/forums/conversions-swaps/460867-ls1-into-vauxhall-astra-coupe.html
Old 04-17-2006, 04:12 PM
conan's Avatar
That little thing should haul *** after the conversion. You have a ls6 intake on that engine so you wont need that. A pully and ported TB will help. Is there no way headers will fit in the engine bay?? You could look at mac's mid length too. Also and I know you said no internals but a mild cam wouldn't cost that much or take that much time to put in.
Old 04-17-2006, 04:23 PM
Pete 1's Avatar
I dont want to sound dumb, but, what is mac`s mid lenght ?
SLP underdrive pulley ok ?
And which mild cam would you suggest ?
So many questions, sorry mate
Old 04-17-2006, 04:35 PM
Happy Jim's Avatar
Pete,
Do the CAM swap while you can get at the engine.
I went for a TR230 (+pushrods/springs/titanium retainers) from Thunder, and also went for the Katech rod bolts for insurance.
Rgds
Jim
Old 04-17-2006, 04:40 PM
conan's Avatar
Heres a pic of mac's next to qtps long tubes.
http://ourworld.cs.com/jrp98ls1/qtpvsmac_l.jpg
If you can fit them or long tubes do it. A cam: something in the 225(+-) duration range, 570-580 (+-) lift, and a 114lsa would have good streat manners. Pully:https://ls1tech.com/forums/showthrea...ighlight=pully
Old 04-17-2006, 09:03 PM
Ric
Ric's Avatar
https://ls1tech.com/forums/generation-iii-internal-engine/481382-torque-coming-out-my-ears-cam-change.html
If you go with a cam swap, check this link out. Don't just toss a cam in, go with something somebody's actually put some thought into.
SLP's U/D pulley will do fine. For more power, try a FAST 90/90 setup(90mm inlet, 90mm throttle body). Put in a lighter flywheel with a stouter clutch. And TRY to fit some full-length headers in there, maybe for a Vette, GTO, or other LS-powered vehicle.
