Kennedale: Sunday Test and Tune..... who's goin??
Originally Posted by Vcious04
Hopefully my "dyno queen" will knock down some low 8's.
Originally Posted by dan03mach
I'm racing Saturday in Rusk at the Bullitt/Mach1 shootout.. Hopefully I'll bring home a 10 sec. slip..
Originally Posted by NickcZ28
You gonna be on sticky tires right?? Ill say 7.3?-7.4? unless the cobra is also smoking Dope now....
Can't launch to hard on the irs., or BAM!
9 Sec. Club!!!
Originally Posted by 1936FordPU
dont get your hopes up with that unless you can drop some 250 lbs
I got the car at a little over 3100lbs race weight.. It will be close but I don't how close.
i already ran a 7.5 @ 97mph with the 10 bolt.... that was with a 1.9 60 ft and 3/5ths full bottle. I launch at 3800-4k... I plan to take it up to 4500 or so.... also will run full bottle. The heat will help since I dont have a bottle heater or purge yet. The True Duals will also help a bit in the topend.
on motor I should knock off a 8.0 or 7.9???
Come on man.. You need to loose that Dinky cam... I trapped 98 easy with my Rex in the white car...on a hundred or so it should at least be 100mph.. Can I drive it?
I will replace the "dinky" baby cam after i get my dart heads... or my 6.0ltr iron block and forged internals.
you know what sucks even more..... I need an adjustable master.... I just purchased a new battery (156.oo for optima red top w/ tax) and I need a new altenator.... mine is toast! only have between 9 and 12 on the gage.
let me know
dan
http://www.texasraceway.com/Events/streetwars/index.htm
is the track now open from 5-9?? I thought it was 1-5??
