Biggest shot on stock motor
Old 04-22-2006, 07:54 PM
MyTA99's Avatar
Default Biggest shot on stock motor
I'm looking at this kit (Harris Speed Works Sudden Impact Big Hit Dual Nozzle Wet Kit). Just wondering how big you can go. I'll be getting a new in-tank fuel pump of course.
http://www.harrisspeedworks.com/shop...cat=364&page=1
Old 04-22-2006, 08:01 PM
camaroextra's Avatar
Most people will say 150 shot, some have done a 200 progressive shot on the stock block successfully
my opinion on the 200 shot is that there is no room for any error, and your block is on borrowed time
Old 04-22-2006, 08:04 PM
sleeperstyle's Avatar
why is that?
Old 04-22-2006, 08:28 PM
Originally Posted by sleeperstyle
why is that?
Iv just heard several stories about 200shot/stock short block combo #7 piston failures. A 200 shot is so close to the limit that the pistons can handle, it takes a lot less of a fuel pressure fluxuation or plug failure to cause detonation.
i do think it could be done safetly, but it would take a lot of experience to design and monitor a safe 200shot/stock motor system that would last long term.
key word=long term.
so im not saying its impossible, im just saying i wouldnt do it myself
Old 04-22-2006, 08:33 PM
cool- thanks for the info !
Old 04-22-2006, 09:31 PM
brad8266's Avatar
Well heres my .02 It seems that when the manfuacturer rates these kits at a 150 shot, you wont get that gain at the wheels. I have a 150 shot and I actually see a gain of around 130Hp at the wheels, so a 200 shot rated may only get you 170Hp, which on a otherwise stock motor seems safe to me, provided the fuel system is up to par, colder plugs and window switch are used. A tune is also good to get. The stock block can handle a good deal of HP. You just dont want to get any detonation while using a shot that high or else it goes boom.
Old 04-22-2006, 09:33 PM
very true. there are kits that actually dyno higher! depends what brand.
Old 04-22-2006, 09:59 PM
SSilverSSurfer's Avatar
thats whats ive seen...especially with the TNT kits which im going to get
Old 04-22-2006, 10:00 PM
MyTA99's Avatar
Well whats the diff between
300 HP with 150 coming from cam, heads, headers with 150 shot
Vs.
300 HP coming from a 300 shot
Old 04-22-2006, 10:05 PM
MyTA99's Avatar
Killed a 350 Z today it was great. The guy had happy tags. I know I'm off topic but I dont get many oppertunities because I drive it one a week.
brad8266's Avatar
Vs.
Nothing, except the 300 shot will probably put out a lot more torque
yeah torque spike
Old 04-22-2006, 10:09 PM
brad8266's Avatar
yeah torque spike
Are you thinking of nitrous lean spike?? I dont have a TQ spike, its high all through the rpm range.
Old 04-22-2006, 10:11 PM
no i meant the sudden spike in torgue when the nitrous hits the cylinders
oange ss's Avatar
all juice motor wont last as long unless you use a progressive controller
Old 04-22-2006, 10:20 PM
MyTA99's Avatar
So the cam, head with an occational 150 squeez will outlast the rare 300 squeez.
Anyone runig a 300 would probably use for track only and then have the 100-150 for the street.
I mean I'm a Nitrous Newbie but wouldn't a shot be safe as long as your fuel system is upto it.
sprydncamd ta's Avatar
if you want to run a big shot then i would consider making it either a dual stage or using a progressive controller but either way i would definetly look at hsw's stand alone fuel system as another safty precaution
Old 04-22-2006, 10:21 PM
MyTA99's Avatar
Also what happens with the wet kit when you run out of juice and your just spraying extra fuel.
Old 04-22-2006, 10:23 PM
MyTA99's Avatar
you've got to be running lower than 12's with a 250 shot.
Old 04-22-2006, 10:25 PM
brad8266's Avatar
Your AF goes way rich, it wont hurt anything though.
