Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
What to look for in a plasma cutter?
Old 04-22-2006, 10:09 PM
BJM
BJM's Avatar
Default What to look for in a plasma cutter?
I found this plasma cutter but I have no idea if there are good and bad ones, what features I need, etc.
Old 04-25-2006, 09:22 PM
TaylorL572's Avatar
it depends on your budget I use a Hypertherm 600 and it works great but its alot more than those i am not sure about them I guess it all depends on how oftem you will be using it. Hypertherms smallest model is probably around 950 if you are looking on spending that I do not know.
Old 04-26-2006, 07:38 AM
mitchntx's Avatar
Mine is a 40 amp Miller and struggles with 1/4" plate. I hope that gives you a reference.
I would look beyond purchase price and discover how much replacement tips cost. The Miller model I have requires very expensive ceramic cups along with the tips. The whole set up is around $60. And if you drop the torch once, the ceramic cup is gone.
Old 04-26-2006, 07:45 AM
oange ss's Avatar
cutting anything thicker than 3/16 you will need a 220v cutter,
Old 04-26-2006, 11:13 AM
BJM
BJM's Avatar
220-240V is not a problem for me. I see that rated cutting capacity is different than the actual depth it will cut. I can't figure out why though. The maximum depth I plan to deal with is 1/2" and rarely at that. Mostly 1/4"-3/8". Can you make multiple passes to cut really thick stuff?
Old 04-26-2006, 01:29 PM
oange ss's Avatar
yes, but it wont be pretty...i have a Lincoln Electric Pro Cut 25 that has dual voltage input with automatic voltage sensing, it is rated at 3/8 but will sever 1/2"...i have yet to try it on 1/2" tho
Old 04-26-2006, 08:22 PM
JRick212's Avatar
I recommend the hypertherm 600 if you can swing it
Old 04-27-2006, 03:40 AM
Silverback's Avatar
Most have 2 different ratings and very few have them both listed and clearly labeled.
Cut generally refers to what you can get a clean cut with and sever is what it will cut but be ugly. I find that what most of them refer to as a clean cut is more like what I would call a sever, and sever well, needs a lot of cleanup and is rarely severed all the way along the cut
Quick Reply: What to look for in a plasma cutter?
