Where to mount bung for trans temp gauge?
Old 04-24-2006, 11:06 AM
gunit's Avatar
Default Where to mount bung for trans temp gauge?
Just wondering where you guys are mounting the bung for the Trans Temp Gauge on your 4L60E's
I assume in the pan?
Old 04-24-2006, 01:38 PM
jmm98LS1's Avatar
The pan is one of the best places to put it. However a lot of folks (myself included) didn't want to mess with that and use the pressure test port above the trans linkage. The sender threads right in, and my gauge is spot on with what HP Tuners says. Just food for thought.
Old 04-25-2006, 12:11 AM
gunit's Avatar
Thanks for the info.
Defintely didn't want to hassle with have to tap the pan and such. Kind of uncomforting, to try and get it done right.
I appreciate the help again.
Old 04-25-2006, 12:50 AM
00NBMCamaro's Avatar
This is where mine is mounted also
Old 04-25-2006, 12:52 AM
buffman's Avatar
here's even a fancy picture to help you find it
Runs pretty accurate IMO with what datamaster reports trans temp is..
Old 04-25-2006, 03:10 PM
Jimmy P's Avatar
What exactly would one have to do to get the bung in the pan? Weld a fitting on the pan, then insert the sensor in teh fitting? Thanks
Old 04-25-2006, 06:34 PM
1QUIKWS6's Avatar
Yup. I used a B&M Tranny Pan Drain Plug Kit. Drilled a hole in the front side of my Derale Deep Cooling Pan, installed the bung and welded it around in place. Sensor threads right into the bung - same threads.
Got to be careful where you choose to drill/install the bung so as to not interfere with any internal parts. I must have checked and re-checked 20X that the position I was picking would not allow the bung to contact any part of the valve body inside - which would stop the pan from installing correctly.
-Jay-
Old 04-28-2006, 12:34 AM
Juiced2000SS's Avatar
Me too. No fuss.
Old 04-28-2006, 01:36 AM
Jimmy P's Avatar
So you guys have actualy confirmed with a scan tool of some sort that you will get a prety accurate temperature reading from using the test port? Were is the factory trans temp sensor in the 4l60E.
Old 04-28-2006, 09:29 AM
jmm98LS1's Avatar
Yes--scanning the car with HP Tuners verified that my gauge w/sender in the pressure port was within 2 degrees of the factory trans temp sensor, the location of which I am not sure of.
Quick Reply: Where to mount bung for trans temp gauge?
