Whats wrong with my friends car??
My friends car does not want to start, it cranks but does not spark, Changed plugs, wires, crankshaft position sensor, starter, alternator, battery. Someone said it might be the security module on the car. Anyone on here wanna second that or give a diagnosis. Thanks.
-John
-John
Sorry man, I can't diagnose this without knowing what color the car is. I do however have the amazing ability to tell you whats wrong with it without knowing the year, make, model, engine size, whether or not it has fuel, fuel pressure, if the injectors are firing, if the coil is plugged in, if you get spark at the coil but not the plugs or if the security light is flashing or not.
If there is no spark and the injectors aren't firing I'd lean towards the vats. Especially with the flashing security light. Clean the key, blow out the lock cylinder and try it again. If this doesn't work you could either start tracing the harness or head to radio shack and buy the correct resistors and wire them in place of the lock cylinder contacts.
As far as I know VATS has never stopped a car thief anyways.
im with him, if the car worked fine than all of a sudden started doing this on its own i would think its the vats.. if you did an intake or cam swap than i would think the coils were unpluged...
Originally Posted by RGV_Z28
Thanks guys. What are the correct resistors and where can I find that lock cylinder??
I haven't done it in quite some time but you wire the resistor into the harness to the VATS module, can't recall exactly which one though.
The lock cylinder is where you stick the key to start the car. Sometimes the contacts get dirty.
