two mufflers in back?????????
i have a friend that wants to put two mufflers in back like the new mustang. lets say two single chamber flowmasters. what would it sound like ..... the exhaust would consist on headers and offroad ypipe going over the axle to two single chambers (or muffler of choice) anyone do this or give some advice on this.....
this is for a camaro not a mustang and it does not have true duals it has a offroad y pipe it will have two mufflers in back it will y into to mufflers yes or no on the sound. i do not want to do true duals. i want to keep my offroad y pipe.....
?? It will not fit, and if it does it is going to cost a fortune to fab up, plus it would all be worthless with flowmasters on it. you might be able to squeeze to magnaflow bullets under there, but I do not understand the login here, basically it will sound the same if not quieter, plus it would add more weight, hang real low and look not to good in my opinion. even true duals do not hang two out back
Somebody on here has a custom dual muffler setup (I think he used Remus mufflers made for a 8 series BMW or something) and it sounded and looked BADASS. I say go for it, because I was thinking of trying it too...
mine is fabricated by a local exaust shop for a little over 500. its true duals(X) over the axle with 2 2-chamber flowmasters. so it can be done and it doesnt cost that much either.
02transam/batmobile why would i have to do true duals i would actually have exhaust setup like the corvette in a way except just have a offroad ypipe going over the axle then split off to two mufflers with tips coming off the mufflers....
Kleeborp the Moderator™
Originally Posted by lsx24
Ls1speed used to have a custom true dual that utilized ATR mufflers although I don't see them there anymore:
Originally Posted by MeentSS02
That's because they had to beat the **** out of the t-top storage area to get those to fit...they have since switched to the mufflers I have now (Magnaflow 10416):
I'd be interested to know to the best of your knowledge was it just a pain in the *** or, did it reduce the space where the ttops normally would go.
