is there such thing as lower compression headgasket on a LS1?
Originally Posted by 2002/Black/SS
so it would be worth it for me to buy one after i get my turbo kit in 2 weeks??
i guess you could put them on but thats a lot of work to take off the heads and change the gaskets just for a little bit less compression... unless you are changing the heads already??
If you want to use the cometic gaskets to lower compression, I wouldn't go bigger than .073 (or whatever size it is). After that, you're really hurting quench. I've never had a problem with my cometic gaskets, even after reusing them 3 times.
