Max weight a 304 tubular header will support?
Old 04-27-2006, 03:32 PM
Boostaholic's Avatar
Default Max weight a 304 tubular header will support?
How much weight is safe to hang off a forward facing 304 header?
Old 04-27-2006, 03:45 PM
Wet 1's Avatar
Pretty much none, or as little as you can. 304 is very prone to cracking as it it w/o expansion joints, adding weight only makes it worse.
Old 04-27-2006, 05:33 PM
Cmarsh's Avatar
How much do you like rewelding?
Old 04-27-2006, 06:01 PM
Fullthrottledan1
Guest
Posts: n/a
Just make a support, its much better in the long run
Old 04-27-2006, 07:25 PM
93formto98T/A's Avatar
I have twin T61S T4 turbos hanging from my 304 turbo headers but am looking into support brackets for longevity.
Old 04-27-2006, 07:27 PM
SScam68's Avatar
Depends on a lot of things.
Layout of the pipes is just one of them.
Old 04-28-2006, 12:42 PM
Ok - next question
Lets assume my turbos have a support welded to the frame (motor is solid mounted) will the expansion of the steel hurt because both ends are solid mounted?
Old 04-28-2006, 01:57 PM
layout will be just like my old setup, in this picture
http://www.ecma-334.com/ttls1.jpg
only difference will be much bigger turbos, and the passanger side turbo will be a little higher to help clear the frame for oil return fitting.
You can see in this picture where it would be easy to weld a mount to the car frame to support a turbos weight
Old 04-28-2006, 01:59 PM
smokinHawk's Avatar
if you do a slip fit youll be less likly to crack, the expansion contraction i think contributes most to the cracking
Old 04-28-2006, 02:27 PM
FUroundeye's Avatar
Stupid question for those of us fairly new to this: what's a slip fit?
Old 04-28-2006, 03:04 PM
Because the turbo is mounted solid to the car, and the header is mounted solid to the motor, which is also solid mounted.
So when the stainless steel expands, there is no room for it to grow if its all welded together but with a slip fit joint it will expand and contract without damaging the headers.
Old 04-28-2006, 03:23 PM
smokinHawk's Avatar
more precisly the tbes may expand and contract where if they were welded solid on the colector they will stress and crack from the expansion and contraction caused by the heating and cooling cycle
on a slip fit the joints slide into each other and has some allowabvle play for the expansion and contraction
Quick Reply: Max weight a 304 tubular header will support?
