New best with a scare
Decided to go play one more time before putting the TH210 tranny in the CE. Just for some fun until the new motor is done.
60'- 1.37 spun and shook the tires a little
330'- 3.73
1/8 ET- 5.66
1/8 MPH- 128.29
1/4 ET- 8.70
1/4 MPH- 161.82
Race weight was around 3,725lbs. Boost peaked at 26.5psi.
Now for the scary part. (Short as possible) Our local track Kilkare has a very short shutdown. Well on this pass the chute got tangled up and didn't help to slow the car at all. I stood on the brakes and ended up melting the brake pad and backing plate on the passenger side. The piston ended up coming out and lost my front brakes. The backs then locked up. By this time I knew I was going in the sand so I started heading to the right so I could cut left and keep the turbo from sucking in sand. I cut left at the last moment and the *** end of the car came around and slid into the sand stopping the car.
Luckily we have a race/parts car in the garage with a good caliper and rotor. So we'll be good to go by the end of the weekend. Then it will be time to see what she'll do with 100lbs out of her.
330'- 3.73
1/8 ET- 5.66
1/8 MPH- 128.29
1/4 ET- 8.70
1/4 MPH- 161.82
LS1TECH Sponsor
Mike get in touch with me next week or let me know when to call you. I would like to talk to you about the 91 and 88mm difference. I hope the 88/98 is still working for you
BTW, if you suck some sand in, just send the turbo our way....lol
10 & 11 Second Club
Glad you were able to save it Mike. That would suck busting both cars in such a short time. Hope everything goes well with replacement car.
I have a ? about an Ohio car I might buy you should know the car. PMing you.
Dave
Dave
Man, that has got to be the WORST feeling! I've heated my brakes up plenty in my 3800lb TA with the turbo (brake boosting) or hitting it, braking, hitting it, braking and I get worried when I feel like I won't be able to stop. I can only imagine going 160+! Glad you're okay man..
so no more inovative 88, replaced with the pte91? ORLY?
why are you putting the Th210 in the CE, whats was wrong with the 4l80e, if you dont want it you can donate it to me, or just let me borrow it.
btw what converter are you using?
glad you didnt bust this one up to, guess steve is the only one to do that
Were putting the TH210 in it to be more competitve at Milan in the Drag Radial class. It's lighter. The gearing is better and the easy stage will help me get up on boost easier. This is only temporary. Will run it this way with this motor and for a short while with the new motor. Then the 80 will go back in to get ready for Drag Week.
We run Midwest Racing Converters.
Deffinately would have sucked to have two busted cars in the garage.
Everyone was saying how they would have been scared and freakin out. But it is different when your in the situation. All I could think of was how would be the best way to get it stopped with the least damage.
Glad you are safe.
Do your 150/160's make you go through plugs a lot?
Originally Posted by LSs1Power
Wow.... LS2 with stock crank? Why? Block isn't stretching or any other problems?
You just may changed my mind about the 370 iron setup.
Who builds the motor has a lot to do with how well they take abuse. Oil pressure is still the same as the 1st pass and it has very little blowby. As soon as the new motor is done this one will be tore down and inspected. W2W or myself will post the outcome.
