New best with a scare
Old Apr 28, 2006 | 05:57 PM
TwnTrboCE's Avatar
Default New best with a scare
Decided to go play one more time before putting the TH210 tranny in the CE. Just for some fun until the new motor is done.
60'- 1.37 spun and shook the tires a little
330'- 3.73
1/8 ET- 5.66
1/8 MPH- 128.29
1/4 ET- 8.70
1/4 MPH- 161.82
Race weight was around 3,725lbs. Boost peaked at 26.5psi.
Now for the scary part. (Short as possible) Our local track Kilkare has a very short shutdown. Well on this pass the chute got tangled up and didn't help to slow the car at all. I stood on the brakes and ended up melting the brake pad and backing plate on the passenger side. The piston ended up coming out and lost my front brakes. The backs then locked up. By this time I knew I was going in the sand so I started heading to the right so I could cut left and keep the turbo from sucking in sand. I cut left at the last moment and the *** end of the car came around and slid into the sand stopping the car.
Luckily we have a race/parts car in the garage with a good caliper and rotor. So we'll be good to go by the end of the weekend. Then it will be time to see what she'll do with 100lbs out of her.
Old Apr 28, 2006 | 06:10 PM
FUroundeye's Avatar
When you can't stop, and you're still thinking about saving the turbo, that's when you know it's true love Glad to hear there was no major damage, I would've my pants.
Old Apr 28, 2006 | 06:25 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Mike get in touch with me next week or let me know when to call you. I would like to talk to you about the 91 and 88mm difference. I hope the 88/98 is still working for you
BTW, if you suck some sand in, just send the turbo our way....lol
Old Apr 28, 2006 | 09:22 PM
Caveman's Avatar
10 & 11 Second Club
Glad you were able to save it Mike. That would suck busting both cars in such a short time. Hope everything goes well with replacement car.
I have a ? about an Ohio car I might buy you should know the car. PMing you.
Dave
Old Apr 28, 2006 | 10:20 PM
BLWN1's Avatar
TH210 tranny?
Old Apr 28, 2006 | 10:26 PM
67Firebird455's Avatar
Man, that has got to be the WORST feeling! I've heated my brakes up plenty in my 3800lb TA with the turbo (brake boosting) or hitting it, braking, hitting it, braking and I get worried when I feel like I won't be able to stop. I can only imagine going 160+! Glad you're okay man..
Old Apr 28, 2006 | 11:22 PM
Toonz's Avatar
Damn Mike! Congrats on the new best and glad you were able to shut her down safe. You guys are having some luck with cars this year!
Old Apr 28, 2006 | 11:48 PM
frcefed98's Avatar
don't even want to imagine what that was like, glad you are OK good drivin for sure
Old Apr 28, 2006 | 11:56 PM
CrawlinWS6's Avatar
Import Patrol
Good save. You probably had some stains in your pants.
Old Apr 29, 2006 | 01:40 AM
NA$TY-TA's Avatar
Originally Posted by BLWN1
TH210 tranny?
Its a Th400 with a 2.10 first gear.
Awsome new ET. glad ya saved the car... i know that was scary......
Old Apr 29, 2006 | 04:52 AM
smokinHawk's Avatar
so no more inovative 88, replaced with the pte91? ORLY?
why are you putting the Th210 in the CE, whats was wrong with the 4l80e, if you dont want it you can donate it to me, or just let me borrow it.
btw what converter are you using?
glad you didnt bust this one up to, guess steve is the only one to do that
Old Apr 29, 2006 | 05:22 AM
DarkblueTA's Avatar
Glad you're alright. Holy cow, that's one thing I never want to experience.
Old Apr 29, 2006 | 07:12 AM
TwnTrboCE's Avatar
The 88 wasn't enough so I went with a PTE91.5 Jose had it to refresh and sold it for me and found me the 91.5
Were putting the TH210 in it to be more competitve at Milan in the Drag Radial class. It's lighter. The gearing is better and the easy stage will help me get up on boost easier. This is only temporary. Will run it this way with this motor and for a short while with the new motor. Then the 80 will go back in to get ready for Drag Week.
We run Midwest Racing Converters.
Deffinately would have sucked to have two busted cars in the garage.
Everyone was saying how they would have been scared and freakin out. But it is different when your in the situation. All I could think of was how would be the best way to get it stopped with the least damage.
Old Apr 29, 2006 | 09:01 AM
Reckless's Avatar
Super Moderator
Nice save Mikey
Old Apr 29, 2006 | 09:31 AM
InconFormula's Avatar
What the hell are you doing up at 6:12 a.m. on a Sat.!!!!!!!!
Old Apr 29, 2006 | 09:50 AM
Bad30th's Avatar
Whew ! Awesome time and nice save !
I bet you couldn't press that brake pedal hard enough haha.
Cheers,
Rob (Bad30th)
Old Apr 29, 2006 | 03:31 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Glad you are safe.
Do your 150/160's make you go through plugs a lot?
Old Apr 29, 2006 | 06:19 PM
LSs1Power's Avatar
Wow.... LS2 with stock crank? Why? Block isn't stretching or any other problems?
You just may changed my mind about the 370 iron setup.
Old Apr 30, 2006 | 08:19 AM
TwnTrboCE's Avatar
Glad you are safe.
The plugs that are in the car now have probably 30-40 passes on them. I do pick up just a little with fresh plugs.
At the time I didn't want to spend the extra money on a crank. Plus Harlan ran a stock crank into the 8's so why couldn't I. Plus I like to push things to the limit and make things work that shouldn't.
Who builds the motor has a lot to do with how well they take abuse. Oil pressure is still the same as the 1st pass and it has very little blowby. As soon as the new motor is done this one will be tore down and inspected. W2W or myself will post the outcome.
Old Apr 30, 2006 | 09:12 AM
Reckless's Avatar
Super Moderator
I think you need to check your clock Stevo! It was 8am, not 6 am. And yes, W2W builds the best engines
