Anyone ever installed an ls1 pcm onto lt1?
Old 04-28-2006, 06:52 PM
The highlander's Avatar
Default Anyone ever installed an ls1 pcm onto lt1?
As the tittle says?
I was thinking on trying this myself... Using an ls1 reluctor wheel with an electromotive crank trigger kit or something similar...
Any thoughts?
Old 04-28-2006, 07:59 PM
1SLO6's Avatar
uhh OK??? Why would u want to do that for.... Do u have a lot of money or are u just realy bored...Besides dont think it can be done.... But like I said y would you want to do that?
Old 04-28-2006, 08:17 PM
01WS6/tamu's Avatar
No can do, relegate this idea to down the shatter now to save yourself the trouble.
Old 04-28-2006, 09:19 PM
ultra 94 z's Avatar
I am running a ls1 big stuff 3 ls1 dfi on my lt1 now uses coil packs and even comes with reluctor wheel and cam sensor that drops in distr hole
Old 04-29-2006, 12:02 AM
OutlawZ's Avatar
yeah well his title says LS1 PCM on an LT1.... YOu can get a COP setup (Coil on plug) setup but I believe you will have to go to aftermarket engine mgmt... like BS3 or FAST..... if you plug in an LS1 PCM even with a COP setup your car will probably never start.... ever....
Old 05-05-2006, 10:50 AM
Can you share some pictures... If you can just get the crank signal working... It can be done.
Old 05-05-2006, 11:14 AM
Honda Hunter's Avatar
Not something worth taking on imho but I would love to see someone else try it because if it works out and proves to be beneficial then they could do a write up and save me the leg work and headache. So I say go for it
Old 05-06-2006, 09:47 PM
ultra 94 z's Avatar
Sorry dont have pics at the monent and my car is at a secret location working out a few bugs abd getting ready to dyno tune when i get it back I will get some pics also my big stuff 3 came with a brand new ls1 wiring harness a crank sensor and cam sensor and a reluctor ring that bolts to my ati balancer nice setup
