QTPs, ORY, Borlamouth and TTP's V3 cam
Old 04-28-2006, 10:03 PM
Roarin_8's Avatar
Default QTPs, ORY, Borlamouth and TTP's V3 cam
Well here is how the car sounds so far. Tuning still needs to be completed but for you guys that want to know how it sounds, well here you go.
5700 RPM pull
Old 04-28-2006, 10:58 PM
Roarin_8's Avatar
I'll take another vid of the full 6600 rpm pull when I go back next week.
Old 04-29-2006, 02:12 PM
SSU's Drunk Typing Whore
Lithium's Avatar
that was only 5700 rpm? sounds badass man.
Old 04-29-2006, 06:10 PM
TTPBilly's Avatar
link doesnt seem to work for me. i tried MF and IE... hmmmm
Old 04-29-2006, 06:16 PM
Mad-Max's Avatar
Sounds good man...
Old 04-29-2006, 07:36 PM
Roarin_8's Avatar
Thanks guys.
That's what I said
Deutch420, I'll try to host the vid on ls1tech's vid section when I get home.
Old 04-29-2006, 08:06 PM
00pewterWS6TA's Avatar
that sounds very good. how much HP are u making?
Old 04-29-2006, 08:10 PM
NEED2SPEEDLS1's Avatar
were those numbers you ran at the track in your sig before the cam?
Old 04-29-2006, 08:27 PM
Roarin_8's Avatar
Yes those numbers were before the headers and cam. New numbers are unknown since they couldn't tune yet because of my V rated rear tires. The full dyno tune will be done on Tuesday when they switch my fronts with the rears since the fronts are Z rated. That's why they only pulled to 5700 instead of the full 6600.
Old 04-29-2006, 09:23 PM
ULTIMATEORANGESS's Avatar
cool.i love watching matt in action.
Old 04-29-2006, 11:09 PM
Roarin_8's Avatar
It was his birthday today. Nick was in the car doing the run.
Old 04-29-2006, 11:29 PM
Roarin_8's Avatar
Here's the vid on ls1tech
5700 rpm pull (ls1tech host)
Old 05-03-2006, 08:58 PM
Roarin_8's Avatar
Here's the 6600 rpm pull. Car made 365rwhp, lost 25 due to my lifters. That's the next thing to get changed.
6600 rpm pull
Old 05-04-2006, 01:20 PM
dug
dug's Avatar
sounds good. sorry about the probs
Old 05-04-2006, 01:27 PM
Roarin_8's Avatar
Thanks, they'll get changed when I do the underdrive pulley.
Old 05-04-2006, 06:49 PM
Mike 00'SS's Avatar
6600 rpm pull
Isn't that the same problem that ULTIMATEORANGESS had (dynoing low numbers with the TTP V3 because of bad/faulty lifters) ?
Old 05-04-2006, 06:54 PM
Roarin_8's Avatar
Yes, I've already spoke with UltimateOrangeSS about the situation. His is more severe than mine though.
Old 05-04-2006, 07:21 PM
Mike 00'SS's Avatar
Roarin how many miles do you have on your car ?
Old 05-04-2006, 07:25 PM
Roarin_8's Avatar
Less than 45K, I'll double check tomorrow morning.
Old 05-05-2006, 12:43 PM
dug
dug's Avatar
From the thread it sounded like the pushrods theyre using is too short. The higher lift cams have to come with a smaller base circle or else it wont fit in the motor. It doesnt make sense.
