People with a Big Cam and no cats....
Old 04-29-2006, 09:48 AM
NeverT00fast's Avatar
Default People with a Big Cam and no cats....
Do you get smoke coming out from the exhaust?? I get smoke on cold start and even when the car is all warmed up. It's not oil smoke, but like urburnt fuel. It's not black smoke, but more a grey/blue smoke though not as blue as oil smoke.
The car is a 03 Z06, PRC stg 1 heads, MS3, Kooks 1 3/4 no cats, stock catback and FAST 36lb injectors.
I asked my tuner if it's because the injectors are too big and it's running too rich at idle. But he said he already pulled the DC back on the inj. and the smoke is just from the combination of the big cam and no cats.
Any ideas? If this is normal, I'll probably be putting back the cats.
Old 04-29-2006, 10:29 AM
PREDATOR-Z's Avatar
Yes it is normal at idle, especialy on cold starts. Overlap of the cam means unburned fuel.
Old 04-29-2006, 11:06 AM
Yah, I def. expected it on cold starts. But when the car is warm also? Like last night, I was driving around for 1.5 hours and pulled over to talk to a friend. And I can still see a lot of smoke coming out especially with my friend's C6 HIDs lighting it up from the back.
Old 04-29-2006, 11:50 AM
Zymosis's Avatar
Yeah there is going to be a little smoke, and its going to smell like unburned fuel. Especially with more overalap. But if you are smokin enough to kill mosquitoes, then we have a problem on our hands
Old 04-29-2006, 11:58 AM
35th SS's Avatar
224/224 tr cam here and 42pounds injector running through offroad pipe and a cutout.no smoke except on cold start.double check your ifr/calibration inj. table.good luck.
Old 04-29-2006, 01:22 PM
Viper's Avatar
I've got it, I don't worry much about it. Little rich at idle.
Old 04-29-2006, 01:58 PM
santiago's Avatar
I only get smoke on start up( white smoke) and after its warmed up there is no smoke.
