Hesitation after header installation
Old 04-29-2006, 12:10 PM
JoeZLS1's Avatar
Default Hesitation after header installation
Just installed pacesetter LTs for 02LS1Z28 w ORY, untuned. Car hesitating on acceleration. O2 sensors i believe are fine, though the back sensors are no longer plugged in. Check engine light doesn't come on.
Could one of my spark plug wires be loose? The spark plug wires went back on a whole lot easier then they came out. Seems like they are loose? Is that normal or did I not get them back on right?
Old 04-29-2006, 12:16 PM
blazinws6kush's Avatar
Just installed my QTPs w/ ory and my car is doing the same, may need tuning.
Old 04-29-2006, 12:18 PM
erikthegoalie's Avatar
tuning guys....
Old 04-29-2006, 01:59 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Yeah check the plug wires, make sure they click twice.
Other than that make sure everything is plugged in like it should.
May need some bosch sensons as well. Its always a good idea atleast.
Old 04-29-2006, 03:25 PM
Zymosis's Avatar
As long as it its not a miss, are you sure you arent confusing this hesitation with just a shift in the power band because of the headers?
A tune will help with this.
Old 04-29-2006, 04:42 PM
Raise's Avatar
your a/f is probably out of whack, but if its a real hesitation, then i would check plug wires first.
Old 05-02-2006, 03:28 PM
JoeZLS1's Avatar
To conclude this board...my severe hesitation was in fact due to loose spark plug wires, at least one probably not attached. I got some MSD's and it fixed the problem.
Old 05-02-2006, 09:21 PM
Full-Force's Avatar
hesitation and misses after headers is almost always one of 2 things
loose plug wire
or
o2 wires are touching headers and have burned them and shorted out and blowed the eng sensor fuse
Old 05-02-2006, 09:35 PM
JDP
JDP's Avatar
ya, my car was fine, i used bosch 02s, and ngk plugs with some msd wires and she runs like a champ
Quick Reply: Hesitation after header installation
