well i did the TB
Old 04-29-2006, 03:19 PM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
Default well i did the TB
came out very nice, over all it was pretty easy. i used sanding rolls to work it down first. then 400,800,1000 grit sandpaper and here is the result. now i'm either going to use caliper paint or get it powdercoated later this week.
Old 04-29-2006, 03:21 PM
SSU's Drunk Typing Whore
Lithium's Avatar
damn that looks good...how long did it take ya?
Ace$nyper's Avatar
That looks great for a DYI job!
Old 04-29-2006, 03:28 PM
thanks, about 1 1/2hour grinding it down and 1-2hrs fine wet sanding it,
Old 04-29-2006, 03:31 PM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
How's the SOTP dyno? I'm debating trying this myself soon
Old 04-29-2006, 08:21 PM
White.Lightning's Avatar
VERY nice Javier. I'm suprised it came out so good with your bad eye!!! hahah JKJKJK. Do I smell a side job?!? $xx deposit on stock TB- ship stock one back once new ported one is installed.....hmmm
Talk to you later
Andy
Old 04-29-2006, 09:07 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Good reflections.
Old 04-30-2006, 12:38 AM
Talk to you later
Andy
fo sho, i'll take a better pic of it once i paint it
Old 04-30-2006, 11:01 PM
i painted it today and it don't look bad at all. i hit up the spring with a wire wheel and it looks like new.
Old 04-30-2006, 11:14 PM
Zymosis's Avatar
Looks great man. I see you painted it in the last pic...is anything else under the hood going with that scheme?
Old 04-30-2006, 11:16 PM
That's what she said...
TheBlurLS1's Avatar
Damn! That looks slick! Post some more pics of the setup!
Wire brush + carb cleaner blinged my spring up like a champ.
I've actually found that a fine wirewheel in a diegrinder will produce near polsihed results on aluminum pieces. I've done 2 throttle bodies, my valvecovers, and the MAF ends (outsides) with my die grinder. You've got to throttle the die grinder well or the wires will fly out and stick in your upper lip, I promise....
I bet you could work that intake manifold over in the same fashion, it will bring a nice bling to even semi-rough cast parts.
Old 05-01-2006, 01:37 AM
i'm going with gloss black and brushed aluminum look.
Old 05-01-2006, 01:39 AM
you wanna see my TT's . i don't plan on doing the intake thats more than i want to do.
Old 05-01-2006, 01:43 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Twins! Woohoo! Lets see it!
