pulling out T56 URGENT!!!
Old 04-30-2006, 06:50 PM
C Murda's Avatar
Default pulling out T56 URGENT!!!
ok so im replacing my horribly damaged T56 with a new one and i dont know how to go about the final steps of removing it. i got all 8 bellhousing bolts out, crossmeber is off, all wires are disconnected, and shifter handle is removed. what do i do about the clutch master/slave? anything thing else i need to do that i havnt listed before i go ahead and start pulling?
Old 04-30-2006, 07:40 PM
8a8mfh's Avatar
All you need to do is push the white sleeve in to remove the line that goes to the slave cly if you haven't already. Some are pretty tight and might need light prying to get it off the engine dowels.
Old 04-30-2006, 09:12 PM
C Murda's Avatar
ya thats actually all i could see left to do but wasnt sure how to do it. im used the the older clutch style t56 from LT1s...thanks
Old 04-30-2006, 09:54 PM
jims73z's Avatar
Just pull the trans out far enough to get an open end wrench in about 2"
and remove the two bolts holding the slave to the front of the trans then just slide the trans out. No need to disconnect the hydraulics. Not sure if this is what you're asking but hope this helps.
Old 04-30-2006, 09:59 PM
01Generalee's Avatar
did u disconnect your drive shaft?
Old 04-30-2006, 10:32 PM
8a8mfh's Avatar
Please look at the picture below and tell me how you remove the slave and don't have to disconnect the hydraulic line to remove the trans.
Inside the red circle with the arrow point to it is where the line connects to.
I can't wait for your reply.
Old 04-30-2006, 11:55 PM
Murdock's Avatar
If you remove the transmission-to-bellhousing bolts, you can slide the trans slightly backwards without disconnecting the hydraulics. Then reach inside and remove the 2 bolts holding the slave to the trans. Then remove the trans and leave the slave attached and hanging under the car.
Old 05-01-2006, 05:07 AM
8a8mfh's Avatar
I thought a few were on the inside, maybe I'm thinking of the automatic. That picture was taken about a month ago the trans is in the car now. I guess that would make getting the top bellhousing to engine bolt out easier.
Old 05-01-2006, 08:12 AM
C Murda's Avatar
yes drive shaft is out haha thought that was a given? but ok im bout to go out in disconnect the hydrualics and swing by a dealer to get a new pilot bearing for the new tranny. thanks guys
Old 05-01-2006, 08:40 AM
Camaroholic's Avatar
That's exactly how I do it.
Don't disconnect the hydraulics = don't worry about bleeding the slave.
