what studs?
what studs?
just ordered the prostars for the front now i need to figure out which studs to buy. the car is a daily driver and the prostars are for track days only. id like to keep my chrome lug nuts but i dont think that is an option with a longer stud as i will need an open end style for my zr1's correct? i see arp offers 2 lengths to fit our cars. the 3.25 and the 2.5 versions. which will i need? remember this is for the front i dont have the rears yet.
I run 5/16 with no grinding. I use the 2.75" studs and they're really not even enough to clear the thick-*** pro-stars. Anyway, to answer your question, the chrome caps won't go over the longer studs. I guess you could put a spacer on when you run your stock wheels just to bring it out enough to be able to use the caps, just a thought...
g
g
Stock studs on the front here, 5/16" spacer to go with them. No grinding was required. I got just as many turns on my lugnuts (SST mags) on the Prostars as I was getting with my stock 16x8s, so I feel safe
