Do we need a sticky with all the wiring diagrams?
Restricted User
Ok, in the last few days/weeks, I'd say about 10% or more of the questions in this sextion are wiring related. So, I am thinking maybe assembling a thread of all the wiring diagrams related to nitrous. Including:
Installation of CF, Edelbrock, NOS, NX, NW, TNT systems, or at least the basics, simply cut n paste from their site, or from using the search button.
Bottle heaters, from the sponsors as well.
MSD WS wiring. This is a dead horse, but the search button seems to not work in the sextion.
Transbrake and 2Step wiring as well.
Any other suggestions?
Charlie
Charlie
i made a post with one. it doesnt include fpss and uses microswitch so im using it and just guessing on the rest... ill have to draw mine up so you can check it over for me.
Hey Charlie I requested awhile back that the links in the post I did be updated/hosted but no one did so a few are broke. The TNT diagram works as well as the Nitrous Express FAQ, but the NOS ones are broke. I think they need to be hosted on tech's server just so we don't have problems like this in the future. JMO
Instead of just pictures as wiring diagrams, can we make them Flash? I'd suggest something else, like the software electrical engineers use but who the hell wants to pay for that, right? I suggest making the diagrams out of Flash since it has the ability to show/hide layers (with a tiny bit of work)... and it's free from Macormedia (the plug-in anyway). Each layer would show just one (or two) wire(s). This would make it 1000 times easier for new people because they could just eliminate each set of wires one by one, by hiding/showing the preferred layer, till the whole job is done. So if I only wanted to see how the wire from the nitrous solenoid connected to the relay, I would have that option.
Your opinions?
Your opinions?
that is a great idea i know that i have give like 4 people one of the diagrams i got when i installed mine in the past couple of days. i think a sticky on just basic installs to like where to run the wire through the fire wall how to mount the noids and the WOT switch and stuff like that. It would have helped me, because when i installed mine i did not know that some made those jimmy jam switches and just tried to make my own.
1 Post
No matter what...you can't sticky the ability to do the work. I'm not suggesting it isn't worth the effort...but the same wiring questions willk be asked...just a new place to send them i suppose.
Originally Posted by reject
i like the flash idea but who here is good at that? and yes for a wireing solo stickie
To many different combinations. 12 different people will want to wire up stuff in 12 different ways even if they all had the same 4 pieces of equipment.
What needs to be put up is a wiring 101 instructional peice. It should show how single pole double throw switches work, double pole doube through switches work, how relays work, how to use switched power or switched ground on stuff, why you need relays for high current applications, good grounding technique, proper crimp connection, proper solder work, T'ing, breaking, splicing, ...proper wire routing, how to come through firewalls via factory groumets and where/how to drill you own holes through the firewall, finding switched and hot 12V signals, finding tach signals, troubleshooting problems, and how to use test lights and volt/ohm meters just for starters.
Folks, and most shops unfortunatley, need to learn how to do it right. The few basics above in an educational format should be able to help a lot more then a stack of wire diagrams. When someone understands it, they don't need a diagram anymore, and they won't need to wait on others to help them.
Restricted User
BMN, would you be willing to contribute a wiring 101 of that nature, and Somebody09 if you will do the flash it'll get stickied. That would allow you to do them as you can, and add to it. I agree for each particular thing there are multiple ways ppl will try doing it, however sometimes I wonder if its done that way because ppl dont have this kind of knowledge/help/input.
Hennytime, for Pro Controllers there are just too many different ones out there, and from what I have seen most all the new ones have a very comprehensive manual, but not sure.
Restricted User
Please send any diagrams to my email, so I can get the full size pics hosted, and included in the sticky.
cat3n4@gmail.com
Once all the emails are in, I wil start building the Wiring thread, and from there see what we need to add, modify, delete etc... Thanks everyone.
Also, include username when email so contributors can be listed after each section/diagram. Thanks.
cat3n4@gmail.com
